Question about IBM X4 Ultrabase Dock (92P3429) Port Replicator, Docking Station
When putting laptop on to docking station (ultrabase ) comes up with this message the trusted relationship between this work station and primary domain failed Can not log on lift laptop off docking station log on then place back indocking station and seems to work fine.
  • IBM Master
  • 4,924 Answers
Reinstall the drivers related with it ..must be a driver error cause seam like a communication issue ..Anyway ..like all devices to communicate have to be both powered and on to assure a instant communication ...so keep that in mind too..
Posted on Oct 25, 2010
6ya staff
SOURCE:
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
No audio from docking station PA3314U-1PRP. Laptop itself (Tecra M5) outputs audio normally. All other outputs from the docking station work normally. How do I get audio to work through the docking...
you should try plugging from the output port of the laptop to the input port of the docking station, remember the source is coming from your laptop going to the docking station.
Now for the microphone once you have the settings right the line in jack should work properly.
Hope this helps!
Jul 22, 2011 | Toshiba Advanced Port Replicator III...
Docking station
typically if it's a complete docking station, it uses your laptop power supply and provides power to your laptop and itself at the same time.
http://www.dell.com/downloads/global/products/latit/en/laptop_latitude_efamily_docking_accessories_brochure.pdf'
according to that brochure the dock is the E series.. and doesnt come with a manual
Dec 11, 2009 | Dell D/Dock Expansion Station Docking...
Dell Latitude 630 docking station USB ports no longer work
Try removing the laptop, unlug the power to the dock and wait a few minutes, then connect the power now put your laptop back on the dock.
I hope this helps.
Have a good day and good luck.
Nov 20, 2009 | Computers & Internet
I have a Latitude D630 laptop and I recently purchased a docking station to use with it. I tried my laptop's PA12 Power adapter When I initially connected everything and placed the laptop on the dock an...
Try updating to BIOS to version A16 from http://support.dell.com Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Nov 13, 2009 | Dell Docking Station for Latitude D600
Blue Screen in docking station
Try going into your BIOS and setting the hard drive from your Docking Station as the primary boot device (1st on the list), then your laptop hard drive
Jun 24, 2009 | Lenovo ThinkPad X200 Notebook
Inspiron 600m,"no input signal check video cable"?
Do you have an external monitor for use when the laptop is on the docking station? If so, does your laptops screen come on when it's not docked?
If you're using an external monitor while the laptop is docked, make sure that the screen selection is for external monitors, by pressing/hold the FN key and then press the F8 key to cycle through the choices between LCD, Monitor/LCD or Monitor only.
Mar 10, 2009 | Dell Inspiron 600M Notebook
2nd Hard drive not recognized
If your using IDE hard drives i would try to put them both on the same cable on the primary IDE controller. Then set you main hard drives jumpers and the second hard drive to cable select not slave. Try to boot if the boot fails your goiong to need a Windows 98 boot floppy with FDISK. You need to start up the 98 boot disk with out CD support then when it reaches a command prompt start fdisk. ONce fdisk is up format and partition the second drive. Now it should work. :) Check that the harddrive is detected in the BIOS, it may have become disconnected, it should also be the master drive on the primary IDE. If the drive is not detected in BIOS there is little chance of it working
Thank you....
Jan 29, 2009 | IBM ThinkPad X31 2672 Notebook
No ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Jan 14, 2008 | IBM ThinkPad T43 Notebook
Open Questions:
See all IBM X4 Ultrabase Dock (92P3429) Port Replicator, Questions
IBM X4 Ultrabase Dock (92P3429) Port Replicator, Docking Station Logo
93 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
