Question about Dell 5100cn Laser Printer
Dell 5100CN Color laser printer - full page wash
After a couple of years of home office use, the printer started printing full page gray backgrounds in addition to the text being printed. After a few weeks, the problem disappeared and now it has reappeared. However insead of the gray background, I am getting a full page (edge to edge) light yellow wash on the entire sheet of paper. What could be the problem? Thanks in advance for your help.
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Posted on Nov 13, 2008
Dell 5100cn Error cod 010-397 Restart Printer
ahmad, does the printer show as default? if not make it. Try test print and make sure all printer compartment are securely closed.
Jan 11, 2014 | Dell 5100cn Laser Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Black color has faded to unreadable Have replaced all components
chean the black cartridege with a cleanex and tap it to see if ink will come outm if it does bor then it has dried out and needs replacement.
Jan 11, 2010 | Dell 5100cn Laser Printer
How can I ignore the low toner error message and print black on a Dell 5100cn?
i believe that if you remove the color toner cartridges, it will stop asking and only print black. you may also be able to specify in the print menu settings to disable the color printing
Jun 10, 2009 | Dell 5100cn Laser Printer
Color printing
When you print something and the window pops up, go to preferences and youll be able to specify "black" as the output color.
Jan 29, 2009 | Dell 5100cn Laser Printer
Dell 3110cn color laser prints with black "haze" on all pages
You probably used a "GENERIC" toner cartridge on one of your toners.
This caused the developers to get contaminated, now they need to be replaced (probably Black & Blue)
Jan 12, 2009 | Dell 5100cn Laser Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Dell 5100cn leaving line only on full color pages
There is more then likely damage to one of the photo developers. This is what transfers the toner to the imaging unit. The Developer frame assembly has to be totally removed in order to change one or all of the developers.
The only other posibility is that the printhead needs to be cleaned, however, in order to clean the printhead you would still need to remove the developer frame assembly to access the front of the printhead.
Sep 26, 2008 | Dell 5100cn Laser Printer
Dell 5100cn
How do I remove a job history page from printing on a Dell 5100cn printer?
Aug 06, 2008 | Dell 5100cn Laser Printer
Error Message on Dell 5100cn
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
412 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
