Question about JBL ES150P Subwoofer Speaker
Ok so i hooked up my subs to my amp i have a good ground, good power to the battery, the blue remote wire is hooked up right, and the rca's are all hooked up right the amp gets power, but the subs just go crazy they are just constantly bumping even without music whats wrong?
5 Suggested Answers
SOURCE:
  • 944 Answers
SOURCE: amp wont turn on
Sounds like a fuse issue in the power from the amp - the remote circuit could be and probably is completely independent. haven't been able to find confirmation on this, but if you are confident to take the cover off then check (probably)around the area where the power terminals are there may be some fuses. Hope this helps, ask again if not :)
Posted on Mar 14, 2007
  • 57 Answers
SOURCE: sub and amp problem
You should get power even without the RCA cable.
I believe you should take time and check your connection.
please use the right cable for your sub. you need the right cable
to boost the sub. Check radio shark or Sam Ask for better sub cable.The better one don't come with your system.
Good luck
Posted on Jul 24, 2008
  • 109 Answers
SOURCE: my amp!
you may not have a big enough power wire to it, and it could also not be grounded good. You have to know the limits of your amp too. They are rated by Ohms of stability. Most amps that small are only stable down to 4 ohms. Most subs have 4 ohm coils, but there are also double coils, and 8 ohm subs. You will need to know the ohms on your subs. If you load your amp down to a lower ohm load than the amp is capable of handling, then it could also cause this.
Posted on May 06, 2009
SOURCE: cant get 4000 watt lanzar amp turned on
they're bridged together to get power...idk why it's like this but it was like that on my TIS 1800 for the life of it and i had to remove the fuse to turn it off since i had no ignition wire to the head...just bridge the remote with the power and u'll get power and it'll work fine
Posted on Nov 05, 2009
How do I hook up a jbl 12 inch subwoffer to a car head unit
The head unit should have a RCA Sub Out. The RCA wire goes to the Sub Amplifier, along with power, ground, and a blue remote wire from the Head Unit. Next, the Sub Amp is wired to the Subwoofer with speaker wire. Without an amplifier your sub won't make any noticeable sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 09, 2011 | 1998 Ford Taurus
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
Wireing diagram to hook up amp sub and 4 speakers
Here's the color codes for the wires.
Blue=power antenna
Blue/white=remote turn on for amp
Red=ignition
Yellow=battery
Black=chassis ground
Grey=right front (+)
Grey/black=right front (-)
White=left front (+)
White/black=left front (-)
Violet=right rear (+)
Violet/black=right rear (-)
Green=left rear (+)
Green/black=left rear (-)
RCA Connections:
Red=right rear to amp
White=left rear to amp
And that should be all the wires. Good luck!
Sep 26, 2010 | Alpine TDM-7582 Cassette Player
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
How do I turn my subs on on my xdm7510 radio
check to see if you have power going to the amp. Battery(+) and Negatve(ground). if those are ok, turn the radio on and check to see if the remote wire(it's usually blue) has power. if you have power on the battery wire and the remote wire from the radio, then there is a problem with your amp. check fuses on the amp if any.
Sep 07, 2009 | Dual Electronics XDM7510 CD Player
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Intstall sub and amp
ok not much info but
u need a red thick wire with a fuse from positive on battery to positive on amp
thick black ground wire from negative on amp to car body
remote wire from remote on amp to remote on back of head unit
rca leads from back of head unit to amp
then hook up sub
Jul 02, 2008 | Car Audio & Video
How do I hook up amplifier?
Well make sure you have enough power wire, remote wire, RCA's make sure they are long enough as well. Now depending on wattage the amp can kick out determins on the power wire size. Run a wire bout a foot from the battery + terminal and add a in-line fuse (once again depends on the power of the amp) now run the rest of the power wire to the back. (along with the remote wire and RCA's) Now hook up your RCA's on the sub output, (If no sub output hook up to the rear) this will connect to your amp RCA's input. Now for the remote wire, wire it up to the BLUE remote wire or power intena, this will go to your remote terminal on the amp. from thier all thats left is your speaker... Hope this was helpful
Apr 22, 2008 | Car Audio & Video
How to instal my deck to a amp and sub
you would need rca cables, power wire, ground wire, and remote wire. it is easiest to just go to your local best buy or circuit city stores and buy the whole set in one package. rca's lead from your decks rca output jacks to your amp, remote wire leads from your decks wiring (blue remote wire that leads to your deck itself to give it remote) or any 12 volt source like where your fuses are located and it runs to the amp also, your power wire will lead from your battery to your amp, and your ground will need a good place somewhere in your car and be bolted or screwed to the frame of your car. this is how to intall your deck to your amp. i assume that you already know that wires will have to be under your carpet or kickboards and such however you run them. i think this covers the basics and i hope i have answered your question right, good luck
Oct 06, 2006 | Alpine CDA-7892 CD Player
JBL ES150P Subwoofer Speaker Logo
42 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
