Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Ceiling fan I have a Quantum ceiling fan 5 blades, I knocked into t and put it out of balance and we can't seem to get it to stop wobbling . I have 4 more same units in other rooms and they do not move at all. Any suggestions
  • 153 Answers
Try grasping the fan motor and turning it a little each way. There is a notch in the support bracket and maybe it was knocked hard enough to move out of the notch.
Posted on Sep 09, 2008
My Hampton Bay Victoria 70 in. French Beige Ceiling Fan has started to sway and make funny noise anything above a level 3
swaying fans are a symptom of out of balance. The blades have to be all at the same height to the ceiling or from the floor . It it was ok before but just started this when the noise started then it may be failing bearing in the fan.
with most fans that means a new one but take it to an appliance shop as it may be repairable.
bearings will be from a bearing supply shop
Apr 01, 2015 | Hampton Bay Dryers
I was trying to see if I could stop my fan from wobbling. After loosening the 2 phillips screws I twisted the upper housing slightly and the complete fan came loose(except for the wires). I just want to...
The fan wobbles cause you bought a crappy Harbor Breeze or Hampton Bay fan. The fan blades need to be balanced with a fan balance kit that comes in the box. You probably threw it out cause you didn't know what the package of weights was for. Get you a Hunter ceiling fan and you won't have an issue with fan wobble, because their fans have better quality control before leaving the factory. If you installed the fan without adequate bracket support- you best get a pro to help you out cause there is no fan wobble help for stupidity.
Jun 05, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Ceiling fan wobbling
put a piece of masking tape on each blade and number them.while you're up there check that mounting screws are tight.switch position of blades,i.e. move #1to #3,see if it's better or worse;switch #2 & #4 or#4 &#6 etc. until you find the combination giving you the best 'balance'
Sep 25, 2009 | Sea Gull Lighting 1555-734 Three-Light...
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Cannot stop the ceiling fan from wobbling. Have
you still have a blade that is out of balance. mesure each blade from the bottom side end to the celing in one spot. Do this for each blade when you find the one that is closest to the celing then you have to place the wheight on the edge of that blade then spin it to make the right adjustment then seta stick on weight where the temp. weight is at
Jul 31, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
Antigua Plus 56" blades brush light bowl & fan wobbles too much.
I learned that your Antigua Plus 56" Ceiling Fan was manufactured by King of Fans, a reputable company out of Florida that offers great customer support for their fans.
King of Fans website is: http://www.kingoffans.com
There are 3 FAQ's to read that can help you there about wobble, the proper size of the down-rod, and the fan hanging straight. Also the fan's description tells you what should be in the product's box. There should have been a balancing kit!
If you do not have your Owner's Guide, you can download it free! At any rate, carefully peruse it and follow the guide instructions, it seems that something has not been properly completed and or parts are missing. If parts are missing call customer service at 1-800-330-3267, and concisely describe the problem. I have found them to be wonderful at their customer service over the years.
Regarding the clearance between the bowl and blades, my first guess is that the blades may be installed either upside down, not pushed in fully, or pushed in too far. Regarding wobble, be sure to check page 9 of the Owner's Guide.
Best of luck! Your fan is gorgeous!
Pegi S.
Mar 08, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan
Hello Capt Treb. Turn off the power. Check all the blade and support arm mounting screws for tightness. Stand on a step stole and view the blades from a horzinal plane to check all blades have the same pitch by slowing rotating by hand. You may have to bend the arms a little to aquire an equal on the plane. To locate a weight balance is a shoot & miss with the balance weights. Good luck.
Sep 26, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
70 people viewed this question
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
