Question about Epic 425 Mx Treadmill EPTL88105 !
The belt goes but as soon as someone gets on it i guess the weight makes it stall.
    New Friend:
  • 15 Answers
Try ajust the rear belt roller, to put more tension on the belt drive
Posted on Oct 25, 2010
SOURCE:
Yamata gc8500 needle thread breaks as soon the machine goes fast
Make sure you're using the correct size needle for the fabric you're sewing.
Delicate / Very light weight.... china silk, fine lace, organza....size 8 or 9 .....Light weight taffeta, lining fabric, thin velvet, synthetic sheers size 9, 10 or 11.... Medium weight cotton nylon, crepe, knits, flannel, spandex, linen, poplin, wool, muslin size 12 or 14..... Heavy weight fleece denim, leather, vinyl upholstery fabric size 14 or 16....Very heavy weight ; heavy canvas ; thick leather size 16 or 18
Apr 28, 2018 | Yamata Sewing Machines
Car stalls out when at stop, check engine light does not come on
you meant, CEL comes on key on but went out running and stayed out, , yes, got you.
but its only for smog, or 100% dead sensors.
its not for weak parts at all.
facts, the Ecu DID WODERFUL things to stop the stall but failed
causes are 50 fold but we use physics top 5
1: lost 12vdc power the PCM/ecU BRAIN (ALAN TURNING ! BRAIN)
2: the engine lost compression, it can hot, or belt slips , cam slip.
3: lost spark 99% of all stalles are customer never tuned car up in 10 years.
4; bad fueling.
5: lost idle air, supply. stalls. now. or EGR stuck open making air bad.
there is a test for each
wana GUE$$ or TEST.
or get it serviced, choice 3, most use.
no engine stated (size)
nor a real question, (why:does it. can someone fix it , yes,, can i fix it , my guess not, no tools, no fix it, and no books .)
get it fully tuned up. why not.?
Jan 13, 2015 | 1992 Chevrolet Lumina
I changed the fuse for the dash lights, it blew out twice. How do i fix that? Also when i turn the ac on, i guess its the belt that makes a loud noise off and on, the ac is cold. How do i fix that ?...
Ok....make sure you are putting in the correct amp fuse. If you are...there is short somewhere. Probably in the dash cluster itself. These are famous for messing up. Now as far as the a/c belt goes. Do not spray it, it will just make it worse lol. Loosen the little pulley bolt that the a/c belt is on. Not the main belt. loosen the actual bolt that goes through the center of it. Loosen it just till it jiggles. Right behind that pulley is a bolt facing straight up. Tighten that bolt till the belt is tight. Then tighten the pulley back up and your finished.
Jun 14, 2010 | 1996 Dodge Grand Caravan
When i turn on my heat my 2004 trailblazer stalls
if this happens while the defrost of ac is turned on, it could be a seized ac compressor which will cause the serpentine belt to squeal and drag making the engine sometimes stall. if it happens with the ac off and the selector on say the floor, or dash vents, the issue could be a bad alternator and battery. this is confirmed when the blower motor engages and the lights dim and then the truck goes dead.
Feb 06, 2010 | 2004 Chevrolet TrailBlazer
I have a Proform XP 550s and the belt skips/slips when you put any weight on it. Works perfect if you let it run without a body on it though. Any ideas on how to fix it? I've tried tightening and...
I would remove the hood first covering the motor (Usually 4-6 screws) so you can isolate the problem. Now you will be able to get a good look at what is going on underneath. If when you put weight on it the you see the motor keep spinning but the drive belt stop then you need a new one. You could temporarily tighten it until you replace it but it's probably ready to go. If the drive belt and front roller keep turning and the walking belt stops then replace the walking belt.
On mine I had to replace the drive belt and the walking belt. I went with the cheapest fix first (drive belt which was slipping) then I could still stall the walking belt but had no way of knowing that until I replaced the drive belt.
I guess if it's the motor you'll be able to tell that too by watching because it'll bog down.
Parts at TreadmillDoctor.com for me anyway. They have both online and by phone troubleshooting support.
Jan 25, 2010 | Exercise & Fitness
Water still in tub water level light blinking
GO TO www.repairclinic.com AND LOOK FOR PART 541811 IT MAY BE CLOGGED AND NEEDS CLEANED OUT THIS IS A LINT CATCHER FOR WASHERS
Apr 16, 2009 | Whirlpool LCE4332P Top Load Washer
Belt stops as soon as any weight is applied.
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Apr 03, 2009 | Proform 560hr Treadmill Walking Belt
My Treadmill Belt slips as soon as any weight is applied. I have tightened the belt but to no avail. It has been suggested the Front Roller requires replacing but this comes as a whole unit with the...
hi..you have to make sure whether your belt is
aligned properly.It should be straight.Make sure
it is not crossly placed.
check it out..
thank u..
rate me..
Feb 22, 2009 | Proform Exercise & Fitness
Airbag light goes off when passanger seat in use, & on when not
even with exchanging the sensor the calibration could be off. without pulling codes from the airbag system it would be hard to guess for sure but id say you need to have the dealership do a recalibration on the seat
Jan 29, 2009 | 2006 Dodge Durango
Hotpoint WF430 Noisy on Spin Cycle
Hi.
It could be loose balance weight, or worn drum bearings.
Remove belt and spin drum by hand from the inside, if you can hear a rumbling noise, or any noise, or it feels stiff to turn then the bearings have failed
If it is under 5 years old, then it should still be under warrenty provided you did not buy it from Comet or Currys.
If it is balance weight, you will be able to feel movement, there is one at top and one at bottom of m/c.
Nov 23, 2008 | Hotpoint WF430 Front Load Washer
Epic 425 Mx Treadmill EPTL88105 ! Logo
81 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
