Question about Sharp AL 1631 Copier
THE MACHINE NOT WORK AND MARK CHANGE DRUM IAM NEED THE CODE FOR ERASER THANKS ALEX
  • 1,110 Answers
To reset the drum light on your AL1631 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 28, 2010
SOURCE:
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
F21 has appeared on my Bosch classixx 6 1200 model
F21 normally indicates a fault with the motor or the main control board. It could be the motor brushes need changing.
If you've changed the brushes you now need to erase the stored errors and try the machine again.
Turn the knob to off.
Close the door.
Turn the knob to 6 o'clock position.
Wait 2 seconds.
The start/pause should begin flashing.
Press and hold the spin button. (the spin button is the one that changes the spin speed, it may be marked "RPM")
Turn the knob to 7 o'clock position.
Wait 2 seconds.
Release the button.
This should erase the error code and get you running again.
If the error code returns, you have a problem with the motor, wiring or main control.
If the machine won't go into diagnostics to erase the error code, it would suggest a faulty control board.
Try it several times to see if you get it reset.
Note, If the start button doesn't flash, just carry on trying to erase the codes.
Dec 22, 2012 | Bosch Classixx WFL 2066 Front Load Washer
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Fuser problem with Brother MFC 9420CN laser all in one
Unplug the printer and allow it to cool.  Then gently wipe off the surface of the photo-sensitive drum with a cotton swab.  If this doesn't work you may need to replace the drum.
Nov 20, 2008 | Brother MFC-9420CN All-In-One Laser...
For xerox work center 420
If you are using oem products than send it back they are reset with a chip within the drum unit
Sep 24, 2008 | Office Equipment & Supplies
Erro code f23-1
If its F2- 31 , its the drum mark problem.The drum may be defective or the wrong drum fixed on a machine.Also clean the drum mark sensor on the drum unit.
Jul 30, 2008 | Office Equipment & Supplies
Toshiba E65
How about the drum bias is it getting grounded. How about this was there a problem there before you did the developer change? Did you replace the opc and reset the counter? How about this... did you switch out one unit at a time... switching them out one at a time till the problem shows up. Also change the primary and trans fer you may have a arching problem???
Jul 17, 2008 | Office Equipment & Supplies
HOTPOINT CTDOOP CONDENSER DRYER
If you can move just the drum(not the whole tub). If the drum is "loose", the bearings are gone! I really dont know how to change them on this machine, but it is usually pretty difficult.
Jan 20, 2008 | Hotpoint Aquarius WD640 Front Load...
Sharp AL 1631 Copier Logo
56 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
