Question about Compaq Presario 5000 PC Desktop
Mouse trouble the computer tells me that the ps2 mouse is disabled how do i find how to go in and enable it
    Novelist:
    Scholar:
  • 134 Answers
Start (button) select control panel / system / hardware / device manager / mice & pointing device / double click, select wheel mouse (or whatever mouse you have) right mouse click, properties, select use this device (enable) - But I'm surprised you are having trouble with it.. Have you changed anything recently? Have you always used a ps2 mouse? Try connecting the mouse & re-booting the pc.. Also make sure it's plugged into the correct port, not the ps2 keyboard port.. Especially checkif you are using a usb keyboard.. Rgds
Posted on Jun 08, 2008
  • Dave117
    Dave117 Jun 08, 2008
    Another thought, you might need to enable the mouse via the BIOS setup.. to get to your bios configuration Press F2 after switching the pc on to access BIOS on.. Be very careful here, you can cause problems by selecting the wrong thing & saving the wrong selection.. Check the menu options for a mouse config. change.. Might be an option there.
Supermicro SuperServer 5013G-M - PS2 error
Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5013/sys-5013g-m.cfm
Is your Mouse a USB mouse or is it a HYBRID Mouse? Look at the bottom of mouse and see what is written. It should give you the: (1-) Name (2-) Model Number & it will either say: "USB Mouse" or "USB 2.0 and PS2 Compatible". If it is USB 2.0 and PS2 Compatible, then it is a HYBRID MOUSE - You should have a - USB to PS2 - Adapter that came with the mouse.
Use that adapter and plug into the PS2 Mouse port - (only if it is a HYBRID). It will automatically configure itself as a PS2 mouse. Now you will have both your Input devices set as PS2.
(2) - If it is a USB mouse, can you obtain a PS2 mouse to temporarily use? If you can; try using the PS2 Mouse Port?
Now you may have to set BIOS on - with regard to:
(1) - Legacy USB Support -(Either Support or Disable)
(2) - USB settings to what Motherboard supports
Try also to upgrade the drivers/bios, if nessesary.
SET LEGACY USB SUPPORT TO "DISABLED" FOR BOTH MOUSE & KEYBOARD IN BIOS.
Good luck
Nov 24, 2011 | SuperMicro Computers & Internet
THe mouse on my lap top is locked .how can i unlock it
The TouchPad is enabled by default. To change the enable/
disable TouchPad setting by using the Fn + F9 keys, see
“Disabling or enabling the TouchPad” on page 234.
You may also change the enable/disable setting as follows:
1 Click Start, Control Panel.
The Control Panel window appears.
2 Click Printers and Other Hardware.
3 Click Mouse.
The Mouse Properties window appears.
4 Click the TouchPAD ON/OFF tab.
The TouchPAD ON/OFF tab view window appears.
5 Select Disable or Enable, whichever is appropriate.
6 Click Apply.
7 Click OK.
The Mouse Properties window closes.
8 Close the Printers and Other Hardware window.
9 Close the Control Panel window.
Or you can get the manual on the link below. Just type in the # code and click on download now. Page 61 tells you how to unlock the mouse pad.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Toshiba Satellite A15-S157 Notebook
Touch-pad mouse on laptop stopped working after i started using a ps2 compatible mouse. What can i do to get it to work?
There are buttons and key combintions on laptops to enable and disable the touchpad.this depends on each models.in general, it is the Fn+F7 key.It may also be some other combinations.So if you can post the model name of the computer, I can give the Exact Key combination
Jun 30, 2010 | Acer Aspire 4720 Notebook
How to disable ps2 on GA-8IR533 Motherboard
PS2 is usually disabled In the BIOS under ADVANCED or PORTS, but if that option is not available, I suggest you purchase PS2-to-USB adapters, then use your usb mouse and usb keyboard in the ps2 ports. Personally, I love ps2. id rather use USB for my cameras and scanners and drives rather than wasting those ports on a kb and mouse.
Oct 01, 2009 | Gigabyte GA-8IR533 Motherboard
No keyboard after install
Dear Sir,
Here is Some Hints to solve your problem.
1.Check the Bios your PS2 ports are enabled,if disabled enable it.
2.Go to the device manager see your PS2 keyboard Driver enabled or not.If disabled enable it.
4.Finally Check your computer with new keyboard.
if all these are correct... you still have a problem
Deffinately there may be a problem with PS2 port of your computer motherboard,Then only one option is remaining, you can use USB to PS2 Converter Cable,Or a USB Keyboard.
If you have any other query post a comment with more information regarding the problem.I will try to assist you more accurately
Jun 08, 2009 | Iwill XP333-R Motherboard
Disabled Touchpad
connect a usb or ps2 mouse to it and re enable it either through device manager or re install the driver for the touchpad ( get the newest driver from IBM's website )
That or you may be able to re enable it through the utility that sometimes is in the system tray.
Apr 10, 2009 | IBM ThinkPad T41 Notebook
I restarted my PC the other night, and now it doesn't recognize any external peripherals (USB/PS2). I've tried other keyboards that I know work, and I also did the same with the mouse, switching from USB...
Dear Sir,
Mar 10, 2009 | EliteGroup P4M890T-M2 (V1.0B) Motherboard
Mouse
HI
Try disabling and re enabling the mouse. Else reinstall the mouse driver. If it still fails you may need to reinstall your OS or get the ports checked.
Oct 17, 2008 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Compaq Presario 5000 PC Desktop Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
