Question about Maytag MER8770W Electric Range
My Maytag 700 has a loose oven door handle any suggestions of getting the door apart to get to the handle screws?
SOURCE:
SOURCE: how to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Posted on Jul 21, 2007
  • 706 Answers
SOURCE: I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Posted on Aug 22, 2008
aborcass
  • 2651 Answers
SOURCE: MAYTAG PERFORM OVEN DOOR,THE HANDLE IS COMING OFF.
in your user guide it explains procedure to remove the door, after emoving the door and layingit flast on conter /table ita amtter of removing sccrews holding on glass, and top trim to get to the screws that holdon hanlde, a little patience is all thats required not hard here
Posted on Mar 07, 2009
  • 2976 Answers
SOURCE: handles fell off of the top oven door on maytag gemini glass top
Open the door a few inches, to the first hold-open stage. Lift the door upward & off the mounting bars. There will be screws along the bottom edge.
Posted on Mar 08, 2009
  • 31 Answers
SOURCE: oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Posted on Mar 13, 2009
My handle on my oven door came off. maytag model# mgr8674aw0
seperate the 2 halves(screwed together ) and rescrew it . door should just lift off when door is part way open
Feb 24, 2015 | Maytag Kitchen Ranges
Kenmore microwave model 721 loose door
Loose bottom hinge - slide the microwave to the edge of the counter, and look at the bottom hinge - you may have to remove something to see clearly. Its likely you are missing a screw or the screws have worked themselves loose.
Jan 20, 2014 | Kenmore 62702 Microwave Oven
Handle on oven door is coming loose; how do we access the screw in order to tighten it?
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Mar 06, 2010 | Kitchen Ranges
Door Handle snapped off
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 09, 2009 | Maytag MMV5165 Microwave Oven
The oven handle to our Maytag stove is off on the right side, How do I get inside of the door to repair the handle? There is no selection for the stoves so I just picked one.
not an easy fix but look for screws or nuts on oven door sides carefully unscrew door should come apart to get to handle to tighten or replace bolt or screw or nut
Aug 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Handles fell off of the top oven door on maytag gemini glass top
Mar 08, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven door handle
Lady, you are going to have to take the door apart to get at the handle screws. The whole door will lift off the hinges, place it down on a flat surface and go from there. You can find your manual with instructions at http://www.servicematters.com/maytag_library/docs/16010107.pdf
If that link doesn't work, go to servicematters.com, click on the Maytag section, follow the links, enter your model number and you will find your manual. Make sure to take your time, these can sometimes be a pain. Catriver.
Jan 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
How to take apart oven door
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Maytag MER8770W Electric Range Logo
96 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
