Question about MSI 845GVM-V (MS-7057-010) Motherboard
I have this moterboard 845gvm-v ms-7057 ver : 1.0 i would like to know wat cpu i can upgrade to my pc speed is 2.40 ghz and i have a socket 478
    Sergeant:
  • 185 Answers
Supports Socket 478 for Intel P4 Northwood/Celeron/Prescott/Prescott Celeron processor
?Supports up to 3.06GHz and P4 Prescott up to 2.8GHz.
Posted on Oct 24, 2010
Testimonial: "hi thank you very much will check for the cpu you helped me more than the manufacturer could THANK YOU!!!"
SOURCE:
CPU upgrade for Compaq SR1220NX Desktop Computer
Hi
The specs for this machine state that it is a motherboard with
"Socket 478 for Intel P4 Williamette and Northwood processors
Supports Intel Pentium 4 processor up to 2.8 GHz
Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)"
In other words, any CPU that is not socket 478 ( a fairly old socket now) will not even fit on the board. You do not mention your current CPU so you need to compare it with the spec above to see if you can improve it. It is an old machine/motherboard, so your money might be better going towards a motherboard or system box upgrade.
Cheers
Oct 14, 2014 | Computers & Internet
What graphics card compatible for ms 7057 mother board
Looks like that motherboard only has PCI slots to use. You can choose any video card that connects to a PCI slot(Not PCI-e, PCI express, or AGP).
Feb 17, 2012 | MSI 845GVM-V (MS-7057-010) Motherboard
Sir I bought Dell Optiplex GX 260 1.8 GHZ, 256 Ram 400 Bus speed 20 Gb hdd machins working very very slow and take more time (4 houre ) for reisntall Windows Xp ser pac 2 how can speed up my...
You can upgrade a PC but in my experience it is far better and is more cost effective to purchase a faster PC. Here is what you do, save all your personal important information from it's hard drive onto a USB flash drive. Now sell this computer and then using the money that you would have used to upgrade it buy a new computer.
You don't want to go lower than a single core 2.4GHz with 512mb RAM. However I do reccomend an AMD computer system. See if you can afford an Athlon 2 X2 250/255 they are very good and don't cost very much. Of course you will need to purchase new components, either from a local computer shop or on the net.
If you want to try to increase the speed of your current PC then you will need to upgrade the RAM to at least 512mb, make sure it is DDR400. The next thing to upgrade is the CPU, I think it is socket 478 so it might fit a 2.4GHz socket 478 CPU must check CPU and mainboard is the same socket or it will not work.
damnor01
Nov 13, 2010 | Dell OptiPlex GX260 PC Desktop
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
why not go with a faster MB and CPU combo?
First to awnser your question yes the Pentuim 3.2 will fit the MB as long as yours is a 800 Mhz Bus speed. And the Board can be configured for the proper clock speed. I would also buy a new CPU fan and heatsink greese b4 you install this CPU. Thee are so many cheap CPU MB Combos out there its almost cheaper to just replace both and get a much faster system.
Jun 03, 2010 | ATI RADEON X1650 Graphic Card
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
Upgrade cpu to 2.4 ghz? is it possible?
You can and they do have compatible ones.
Oct 12, 2008 | Compaq Evo D310v PC Desktop
Micro star ms 7091
Do you know what the CPU socket is or chipset? If the CPU socket is a 478 then no dual core. If it a 775 then you might be able to use a Pentium D dual core w/ 800MHz FSB.
If you have a 945 chipset then the above will be true.
Jun 05, 2008 | Medion MED-1511 PC Desktop
CPU Upgrade for Compaq (283983-001) Motherboard
download and run everesthome
click on the + by motherboard
click on cpu then click on motherboard
the cpu will id the the processor
motherboard will id the FSB speed.
CPU-Z
click on the download latest version, left column
when you unzip and run this it will tell you if the processor is 478 or 479 pin both have 478 pins but location is different.
Mar 29, 2008 | Compaq (283983-001) Motherboard
Emachine T4150 CPU upgrade
Your processor is a Pentium 4 processor that uses there are 3 different type of sockets for Pentium processors. Socket 423, socket 478, and the latest one is socket 775.
Based on the information here:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T4150
Your MoBo has a Socket 478 and since it only support 400MHz bus, then your maximum upgrade is 2.0MHz, because all other devices faster than that, need higher bus speed that your Mother Board does not support.
Hope you find the answer useful.
Best regards,
/Farhad
Jan 14, 2008 | Computers & Internet
MSI 845GVM-V (MS-7057-010) Motherboard Logo
586 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
