Our small TEAC TV will not tune into channel 7, We sometimes receive it for a few minutes and then it pixelates, the sound goes and then a blank screen tells us no signal. We have other TV's on the same aerial that receive channel 7 and if we connect another TV to the same cables we receive channel 7 OK so it seems to be within the TV itself. We have tuned it through the menu 3 times now to no avail. Please Help
6ya staff
SOURCE:
tvtek
Don
  • 1284 Answers
SOURCE: After power outage, TV screen is blank
It sounds funny but, unplug the set for 30 seconds to allow the TV to reset then see if the problem still is there.
Posted on Apr 12, 2007
Anonymous
  • 579 Answers
SOURCE: tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Posted on Jan 10, 2008
chrispurs1
chris pursloe
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
Anonymous
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
rusellk
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
Teac cx 200idab
Most likely cause = loose/ dirty docking connector. Try a spray of wd40 on that.
Aug 14, 2014 | Teac Audio Players & Recorders
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
I own a TEAC AG V1020 receiver. One channel keeps cutting out then and back in after a few minutes. When I give the volume control a quick twist louder then back down, the channel returns for a few minutes...
Turn it off and vigorously operate all mechanical controls throughout their ranges many times with special attention paid to any Tape Monitor or other rarely-used controls.
Jan 10, 2011 | Teac AG-V8060 Receiver
Pixelation of TV channels via Settop box
Pixelation is caused by poor signal strength. Check the signal strength in the setup section. Unfortunately some boxes and TVs don't handle poor signal as well as others. It might be worthwhile trying a signal amplifier
Jun 12, 2010 | Televison & Video
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Aug 24, 2009 | Televison & Video
Sound Cutting Out
Somthing is tripping th amp breaker...
Try unplugging it for several minuets & see if clearing it helps..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Teac AG-780 2 Channels Receiver
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Switches on then off then on then off...
The first thing to try is to see if your set has loose conections,you need to remove the back and tap in diffrent areas of the chassis to see if it reacts,if it does you'll know soemthing is loose and it has to be resoldered,if you are familiar with tv service you will have a place to start checking but if you are not too familiar seek the assistance of a servicer,the repair should not be expensive.Let Us know how it goes or if you need more information.
Oct 20, 2006 | Toshiba 57HX83 57" Rear Projection...
Open Questions:
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
