Question about Samsung SCH-a670
Found an old samsung which would light up and say need to charge battery so bought a charger and now it won't do anything. Don't know how I got it to turn on in the first place... would press some buttons and it would just turn on but didn't know which ones made it happen.
  • 943 Answers
Try changing the battery with a new one or or you are sure works and see if it works if not send it for repairs
Posted on Oct 24, 2010
SOURCE:
My Lumia 520 is dead! It wouldn't charge, so I bought a new battery, the battery worked till it drained now it won't do anything. Checked the battery points & charger entry, don't know what else to do
Hi , you have to check that you might need a new battery charger. The new battery the bought had a charge then you used it up it sounds like your charger might have the light on but is not charging.
Dec 27, 2015 | Nokia 5700 Cellular Phone
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My samsung R440's charger is not working, I don't know why? But the battery adapter is still lighting
It looks like your charger has died. Check if it has been damaged. You can purchase another one from a nearby computer shop or from Samsung.
Aug 20, 2012 | Samsung R440-JT01
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
WHEN I CHARGE MY NIKON LITHIUM ION BATTERY THE LIGHT FLASHES FOR A FEW SECONDS AND GOES OFF. IT IS NOT A CONSTANT LIGHT WHICH IS A SIGN OF THE BATTERY HAVEING BEEN FULLY CHARGED. cAN SOMEONE TELL ME WHAT...
mcdevito75 here, Try a different battery in the charger if the same thing something wrong with the charger if not the same thing your, first battery is old and won"t take a charge. Age with these Batteries don"t really count, after so many charges they still have to be replaced.
Jul 03, 2010 | Nikon EN-EL6 Lithium-Ion Rechargeable...
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Samsung SCH-a670 Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
