Question about GE DVLR223 Dryers
Dryers humms but doesnot turn - GE DVLR223 Dryers
  • GE Master
  • 8,220 Answers
Broken belt?
Bad glides?
Broken bearing?
All of the above? LOL
Check out this artiucle I wrote for FixYa:
How it works: GE clothes dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 24, 2010
SOURCE:
Why does my maytag dryer when turned on get red hot instantly, yet the motor only humms?
quit buying parts ur motor is shot and u should be or soon be smelling a wireish burning smell.
Oct 08, 2014 | Maytag Dryers
I have a affinity dryer that just humms when I turn it on. I have power 220 at recpt. no code reading?
Sounds like the motor could be locked up, Is the dryer turning if not belt broke , Check belt, take the front access plate where the motor is located and turn it on check to see if the shaft of the motor is turning at normal speed and again check the belt, with power off and belt is not broken by hand turn the drum to make sure nothing is blocking it from spinning freely. if that is free and clear than my bet is on the motor itself as it sounds like it is in locked rotor.
Cause's of locked rotor
Motor seen its better days
if equipped the start/run capacitor could be out
Hope this helps.
Mark
master Electrician
Sep 19, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I turn the start knob and there is just a humm. The drum does not start to turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | GE DBXR463EBWW Electric Dryer
It hummes when you hit start
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Frigidaire Electric Dryer
The dryer humms when I go to turn it on but the drum won't move
heatman101
Oct 13, 2010 | Dryers
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
Dryer humms but doesn't actually run.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 03, 2010 | Hotpoint NVL333EY Electric Dryer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Just humms when you try to turn it on,want start
Dryer motor is bad getting hot causing it to turn off
May 06, 2009 | Dryers
Motor humms and barrel will not turn
CHECK THE PUMP IT MAY HAVE A SOCK IN IT I FIT DONT THE MOTOR IT KAPLUT AND YOU CAN CHECK THE MOTOR BY REMOVING IT FROM TRANSMISSION AND PUTTING IT ON THE FLOOR AND TURNING MACHINE ON
Jan 08, 2009 | Kenmore 75944 Gas Dryer
GE DVLR223 Dryers Logo
65 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
gbob59
Are you a GE Dryer Expert? Answer questions, earn points and help others
