Question about Sharp LC-19SB14U 19 in. LCD TV
I can't change the "View Mode" from STRETCH on HD channels. What do I do? Also I can't find a manual.
  • Sharp Master
  • 736 Answers
If using a cable box change the resolution to 720p. Adjust size with the cable box's remote. It should have an hd zoom # button or format button. If you are using an antenna or no cable box some channels are just going to display that way and there won't be any way to change that. The manual can be downloaded here: http://www.sharp.ca/manuals/default2.asp
Download the one for the LC19SB24U
Posted on Dec 04, 2010
SOURCE:
Hd channels need to adjust stretch and normal view
That usually is an adjustment made on whatever source you have hooked to the tv. Some tv models will minuliplate the picture but not all.
Feb 04, 2014 | LG 47LG70 42 in. LCD TV
Vertical and horizental picture expand and please help me to adjust it
It might help if you listed the brand and model of your TV, but usually on the remote you will see some sort of mode button. You can change the picture size there. Or you can go into your system menu and change it in the display menu. The typical ones are widescreen, zoom, stretch, etc. Also try changing the picture aspect ratio. 16:9 will give you widescreen while 4:3 will give you regular. Also, another problem might be that the channel you are watching or your cable box is not in HD. If the channel is not specifically an HD channel, the widescreen setting will not work properly and you will need to adjust it to a different setting to keep from getting the black bars on the side. Hope that helps.
Mar 16, 2011 | Televison & Video
I do not have a full screen with most channels even with view mode set to stretch oe S.stretch
most channel are broadcast in 16:9 format. you can stretch the picture somewhat but it wouldnt look right on fullscreen anyway.
Nov 28, 2010 | Sharp LC32D47U 32 in. LCD TV
I can't get my view mode to change. It is on stretch right now but is cutting off the bottom of the screen. The other view modes don't show up . My remote works on other things but not this feature.
If you are connected to a cable box or a satellite receiver make sure its resolution is set to 720p then look on the remote that came with it for the hd zoom # button. You may have a format or aspect button on that remote to change the picture size
When the resolution on the connected device is wrong this can happen.
Aug 27, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Screen shuts off. Power lite blinks. Aquos 42"
Hope you have the correct resolution selected:
HD View Modes: When viewing an HD program you can select the following 4 viewing modes.
  • Stretch: suitable for viewing 1.78:1 DVDs. When viewing 1.85:1 DVDs, this mode will show thin black bands at top and bottom of the screen.
  • Dot by Dot (1080i/p only): detects the resolution of the signal and displays an image with the same number of pixels on the screen. When a 720p signal is being input, the image will be delivered in full screen.
  • Smart Stretch: suitable for stretching 4:3 programs to fill the screen.
  • Zoom: suitable for viewing wide-screen 2.35:1 aspect-ratio programs in full screen.
PC View Modes: You can connect the TV to your PC through the HDMI inputs to use the TV as a monitor. The following view modes are available in PC mode.
  • 4:3 Input Signal: You can select between Normal, Zoom, Stretch, or Dot by Dot.
  • 16:9 Input Signal: You can select between Stretch or Dot by Dot.
Also verify if you have set auto timer to 30 mins or so thats why the TV shuts down after a particular time.
Thanks
May 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
View mode incorrect after connecting to pc
hi my name is mark, i own an aquos, the side bar are normal. not all programming is broadcast in wide screen. if you watch during primetime you will see the bars come and go depending on if the program was taped in 16:9 or 4:3 format. you will see it on commericals also. thanks for your question.
Mar 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV will not stay in Stretch Mode
I know of no solution for this, it is the normal operating mode of the system.
Jun 28, 2017 | Philips Magnavox 51MP392H Rear Projection...
I have two Sharp Flat Screen TV model # LC-26SB14U. One is hooked up to a regular Dish Network HD receiver. The other is hooked up to a HD DVR receiver. Both are hooked up to the same Phillips DVD player....
if you using the component input on both tvs I will check the settings on the receivers, "HD setup", the difference is because the settings are set one on 480i and the other on 1080i
Dec 02, 2008 | Sharp Televison & Video
Sharp AQUOS LC-60C52U
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Sep 08, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC-19SB14U 19 in. LCD TV Logo
400 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
