Question about Nikon Coolpix 4100 Digital Camera
Nikon Coolpix 4100
Camera just seems to have died. Will not turn off. Lens stuck in out poistion.
  • 6 more comments
  • Anonymous Jun 28, 2008
    My lens was stuck in. When pressing the on button it flashed green. Nothing more happenned. Because of the light coming on - at least flashing - I did not consider the batteries. However, after reading the solution here, I did. The camera is FINE!
  • npadma2008 Jul 18, 2008
    even after replacement of new batteries, it is not responding
  • emailannaj Oct 26, 2008
    I have the same problem - the camera will not turn on even with new batteries. ~Any suggestions please?
  • aydinakkose Dec 02, 2008
    hi there, my nikon 4100 had very blurry images a few days ago. and nowadays the lens does not extract and there is an error message "lens error" on the lcd and the lens still does not extract. How I can solve this problem* Thanks for all your helps in advance...
    aydin
  • boyfuds Jan 07, 2009
    I have the same problem, even if i put it new alkaline batteries. Sometimes, the green lamp beside the on/off button will light up, but still the lens are still stacked up and still no image in the LCD.
    Do you know where it can be repaired? Thanks.
  • dr_pudge Feb 01, 2009
    I have the same problem. My Nikon Coolpix 4100 seems to have died with the lens out. The on/off switch is flashing, the LCD is black and it won't turn off. When I change the batteries, the light stops flashing (obviously) but the lens doesn't go back in. Help!
  • stefano sc Apr 14, 2009
    I have the same problem. My Nikon Coolpix 4100 seems to have died with the lens out. When I change the batteries, also if brand new the lens doesn't go back in...seem to be really dead. Help!!!!!!!!!!I wrote to the Nikon Customer Service... If I will discover something I will inform you.ByeStefano (IT)
  • Eddye Mueller Aug 08, 2013
    When turned on, the lens fully extends before completely retracting, so I'm hesitant to take her apart. The idea of getting a new battery makes sense, even though the current battery appears to be fully charged. Do they just "wear out" after a while?
How wbout changing your batteries. mine does this if my batteries are dead.
Hope this helps
Posted on Jun 19, 2008
Gents and ladies, open the body of the camera carefully, expose the front end. use can of compressed air around the lenses to hopefully blow out any dust particles. Hit every nook and cranny. attempt to turn camera on and off and on. If your lens won't retract or extend, but your power is on and "lens error" on screen, go deeper, remove several screws to remove the lens--be slow and gentle!! Might be good idea to just loosen the tiny screws first to gently giggle the lens while blowing air into the area. As you press the power button, you should be able to hear the little motors trying to extend or retract the lens. try to work the jam loose--gently.
I speak of experience--i had given my camera up and bought other ones to replace it but one day I decided to try to fix it. this is after my son had gone to the beach with it and it never worked again.
the lens would not come out and "lens error" was on the screen.
sometimes it would power on, other times it did not. But, after fiddling with it for awhile and taking the plunge unguided, the camera finally extended and retracted the lens and took a few pictures of my fingers!! Needless to say, there was quite a bit of sand inside the casing and moving gears. Now get after it and save your camera!
Posted on Sep 11, 2009
Why is my lens still stuck, and why does it not seem to charge?
Send it back to Nikon for repair, or buy a new one.
Jun 09, 2014 | Nikon COOLPIX S3300
When i t turn on my Nikon coolpix L810 i keep getting a message to"turn off the camera, remove the lens cap and then turn back on." it seems like the lens starts to expand and then retracts as if it's...
I'm afraid that you are right about the lens being stuck.
The camera has several checks to make sure the lens can zoom freely in and out. If the camera detects there is a blockage of some kind, the lens will retract and switches of the camera to prevent more damage.
I'm afraid there is nothing you could do to fix it, other than bringing it to a repair shop and have them take a look at it.
Jan 02, 2014 | Nikon COOLPIX L810
Lens stuck and I cant get the camera turned on. I have a nikon coolpix s4100
Low battery voltage left the lens in a position that the electronic circuit can not resume the next operation. Its a typical Nikon digital camera problem. The tolerance on the lens barrel maybe too tight. The solution maybe replace the lens assembly.
Feb 10, 2012 | Nikon Coolpix 4100 Digital Camera
Lens error message comes on when you turn it on
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 26, 2011 | Nikon Coolpix 4100 Digital Camera
My brand new cam nikon coolpix S 4100 got stuck while i was editin a photo...battery is full, unable to switch the cam off.
Pull the battery, try again, if it continues to fault I would take it back and get a replacement.
Oct 11, 2011 | Nikon Coolpix 4100 Digital Camera
Nikon coolpix L11 Lens stuck
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Sep 28, 2009 | Nikon Coolpix L11 Digital Camera
What can I do when I get "Lens Error" on my Nikon4100 coolpix?
Check to be sure there isn't an obstruction that is keeping the lens from extending and be sure the battery is fully charged. If you find and clear an obstruction, just turn the camera off and back on and it should be okay. If none of this helps you will have to have a NIkon authorized repair service work on it for you. You can send the camera to Nikon for service or you can look up an authorized dealer in your area.
Jul 22, 2009 | Nikon Coolpix 4100 Digital Camera
Nikon Coolpix L11 Error....
Assisting the lens gently when it opens and shuts may work.
Dec 28, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon coolpix 4100 playback menu
My screen shows "Lens Error" when i on the camera. Anybody has the same problem? how to solve?
Dec 16, 2007 | Nikon Coolpix 4100 Digital Camera
Nikon Coolpix 4100 Digital Camera Logo
695 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
