Question about Gateway GM5260 PC Desktop
Sound has suffered clarity due to white noise as of recent. I have a a Gateway GM5206 desktop running Windows Vista. I've had it for nearly 4 years and had little issues (none involving sound). I tried re-installing drivers and troubleshooting my speakers but the problem persists. I noticed during my speaker troubleshooting that when I removed the network cable the noise subsided substatially. I tried changing network cables to no avail.
6ya staff
SOURCE:
Anonymous
  • 5 Answers
SOURCE: no sound coming from new hp monitor through windows vista
Alright, I got the answer for ya, first, go into your control panel. Click on Sounds and Audio Devices. Listed in this window should be the name of your sound card. Under that, should be Device Volume, and at the bottom, should be the Speaker Settings, click into Advanced, next to speaker volume. It should show you a diagram of a monitor with the amount of speakers it has selected shown next to it. Where it says Speaker Setup, click and then scroll down until you see 3 settings labeled Monitor Stereo, Monitor Stand Stereo, and Monitor Mounted Stereo. Whatever one enables the sound will be the one you want to stick with.
Posted on Feb 25, 2008
Anonymous
  • 151 Answers
SOURCE: Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
Posted on Dec 29, 2008
ecvolvo
  • 7 Answers
SOURCE: my gateway desktop pc's sound won't work after installing windows
try to open your device manager and see if u have any ? marks (yellow) right click and restart it should work
Posted on Jan 04, 2009
Anonymous
  • 447 Answers
SOURCE: Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Posted on Mar 24, 2009
arpit47
arpit jain
  • 162 Answers
SOURCE: no audio output driver installed
http://nodevice.in/driver/category/SOUND.html
you can try in this site you may found many of audio drivers
Posted on Jun 28, 2009
Dx4640
Take the power supply and use it with another known working computer. If it works, then the problemo lies with your mo bo. Replace it with the gateway part number for the mo bo and ignore the other stuff. If you can do a "repair" operation with your OS you might be able to avoid reloading the OS and all of your programs all over again and save lots of time and aggravation. Can do with XP, maybe with Win 7.
Mar 30, 2014 | Computers & Internet
Buzzing/whining noise while on charge.
This sounds like a cooling fan issue, inspect that....Clean the unit while you're in there, heat kills.
Feb 29, 2012 | ASUS Eee PC S101 (EPCS101B-BLK043X) PC...
My gateway 506gr came with XP. I upgraded to Vista, and now to Win 7Ultimate. I can't seem to get the correct audio driver for this desktop pc on windows 7. Vista, everything was ok
There have been alot of problems with Windows 7 and older software compatabilty. I have conflicting info on what audio you system has. One says Realtek:
http://support.gateway.com/us/en/product/default.aspx?partNumber=4367
This site supports up to Windows Vista but, in some cases Vista will work with Win 7. You can also try here:
http://www.realtek.com.tw/DOWNLOADS/
Another said Intel, which you can try here:
http://downloadcenter.intel.com/default.aspx?iid=subhdr+downloads
With Intel, click on the "run Intel Driver Update", and let Intel scan your system, because they will let you know if your sound is theirs or not. What it may come down to is, if you can't find a driver, and, want Windows 7, you may have to upgrade to a sound or graphics card.
Good luck,
Dave
Jun 11, 2011 | Gateway 506GR PC Desktop
I am not expert in computer,my sound from desktop when i start and when i play itunes,vlc media,media player its playing video but no sound it was working from last 4 years ****. please help
Have you changed anything in your settings or setup recently before you lost sound? What platform are you running? Windows 98, windows 2000, Windows XP Home, Windows XP Pro, Windows Vista, Windows 7? or something else
Jan 06, 2011 | Computers & Internet
I cant log in to my computer Windows Vista (due to a failed system restore). Now when I go to the login it has a blank user named "other user". That happens in safemode, repair system, and...
You need to access the BIOS - press F1 or F2 (depending on the version)during the start of the desktop - and in there you must modify the boot order: put the cd first then the had disk second. Save the change, reboot, insert the Vista disk and reboot once more - the disk will be loaded.
Jan 03, 2011 | Gateway GT5622 PC Desktop
No sound coming from soundcard. Intel 82801DB/DBM 'AC97
you might have to go to www.microsoft.com and look for driver updates for your sound card for vista .
Jun 19, 2008 | Intel Premier Resources 4-Channel 32-Bit...
Problem with speakers and printer
sorry, i missed the headline, this is the driver for the sound if you use xp:
http://support.gateway.com/support/drivers/getFile.asp?id=20551&dscr=Realtek%20HD%205.10.0.5152%20Audio%20Driver&uid=188752169
if you use vista:
download and install it, tell me what model your canon printer is so i can send you a link for the printer drivers.
Mar 02, 2008 | Gateway GT4016 Desktop PC
Gateway GM5260 PC Desktop Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
