Question about GE Ovens
I have a GE Double Oven (electric) model #Jtp27... The bottom oven is perfect, the display seems to work great, the broiler on the top works great but the top oven when baking won't go above about 200 degrees. I'm thinking about replacing the heating element but any guidance would be great. Thanks.
  • brentedgar1 Oct 27, 2010
    Simple fix. Oven is 100% again.
  • 6,993 Answers
Replacing the heating element isn't a bad idea. You will be needing a screw driver to achieve this. Follow the below instruction on how to successfully replace the heating element of your GE Oven.
Stove Top Heating Element
  1. Unplug the GE range from the wall outlet.
  2. Lift it up enough to clear the reflector bowl. Pull the element away out of the terminal block.
  3. Insert the replacement element into the terminal block. It should have a snug fit. Once it is in the terminal block, gently lower the other until it sits in the reflector bowl.
Oven Heating Element
  1. Remove the screws attaching the heating element to the back of the oven using a screwdriver.
  2. Pull the element toward you. Disconnect the element from the wire connectors. Pull each wire at the connector to remove them from the heating element terminals.
  3. Connect the new heating element to the connecting wires by pushing the wires on the terminals.
  4. Attach the new heating element to the back of the oven using the attaching screws.
Good luck.
Posted on Oct 24, 2010
SOURCE:
My top broiler won't turn on. Everything else works fine. I have exchanged the top broiler element with the bottom. So I know it isn't the element.
Could be wiring. Did it work before? Maybe, never connected? Could be demand of two oven's and or broilers at the same time exceeded the wire and circuit breaker capacity when installed and therefore were never connected.
Otherwise thermostat. Probably need appliance Tec or Electrician.
Mar 04, 2015 | GE JTP27 Electric Double Oven
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
Only bottom of the electric double wall oven works . lts a 1969 G.E.
If you can, test for power to the element in the top oven. If there is power coming to the element, it could be that the element is bad and can be replaced. If there is now power coming to the top oven there could be a more serious issue in a 40 year old oven
Nov 30, 2009 | GE JTP27 Electric Double Oven
GE JTP27 oven, ERC display completely lit, keypad
Yes, this is a problem with the ERC. You can buy a new one, or we can rebuild it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | GE JTP27 Electric Double Oven
F8 on Ge JTP27 Whats wrong?
The reason to get F8 is that the component failure that occured within the Electronic Range Control (ERC) effecting temperature processing circuits. Th perfect fix for this problem is to replace Electronic Range Control (ERC).
Sep 04, 2009 | GE JTP27 Electric Double Oven
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
No power to oven
No watvto know about the fuse without a model #
Nov 04, 2017 | GE JTP27 Electric Double Oven
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Bottom oven gets extremely hot
It would appear you have a faulty thermostat that controls the temp. SUggest you get a new thermostat fitted.
Dec 08, 2008 | GE JTP27 Electric Double Oven
Ovens Logo
302 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
