Question about Home
Hi, my shower makes the more noise than usually but no water comes out.. help!!
    New Friend:
  • 120 Answers
Clean the filter of your shower
Posted on Oct 25, 2010
SOURCE:
Hi,After my wife had a shower the pressure in the pipes seem to drop heavy.Not just in the shower but the whole house's.Cold water comes out like a dream but dont know if it can be the pressure valve.
That sounds like a supply problem if it affects all taps (faucets). With no water running in the house, take a screw driver and put the blade on an uncovered supply pipe, put the other end to your ear and listen for a shushing noise. If you can hear it, you have a leak in the supply outside. Call the water supply utility. If there is NO noise, contact them and ask if they are throttling supply for the summer.
Jun 30, 2015 | Home
My 12 yrs old house has now got excessive clonking noise coming from the internal pipe system-seems to occur every 20 mins or so-even I believe caused the fracturing of the backing plate where clamp...
Normally clonking noises are caused by loose pipework.
As the valve closes the inertia in the water bangs the pipe against the wall.
For instance in heater radiator systems it can also cause a continuous banning noise when water under pressure is pumped through it, usually in sync with the rotation of the pump motor.
Mar 13, 2015 | Home
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
We still have water coming from the shower hose but no power behind it. The shower is making a straining noise. What do you suggest?
You have garbage in the unit,teflon tape- pipe dope-rust particle,take apart and flush.Hope that helps
Jan 27, 2011 | Home
SHower noise
Loose washer in hot or cold tap. Replace or tighten.
Sep 10, 2009 | Water Pik Shower Head
Water does not come from the shower head
If your showre head has an external adjustment (usually on the face of the head) make sure that it is opened. Shower saver type valves have a push button on the pipe from the wall to the showerhead, usually close to or are a part of the showerhead. Make sure that it is opened, if you have one. Once done, remove the shower head and turn the water on. If you get water, look into the shower head. Most come with a water restrictor and it can come out of position and block the passage of water. The restrictors can vary in appearance, but usually they consist of a rubber washer and plastic disc, and are in the back of the showerhead where it unscrews from the piping from the wall. If you can get water without the shower head on, but no water through the showerhead, you can take it apart and look for restrictions or just replace it. If you cannot get water after all that, the problem is in your faucet or piping. Most Delta single handled faucets that I'm familiar with have a spring and cup washer valving arrangement. Those equipped with scald gard are somewhat more difficult to work on. Parts are available from H/Depot, Lowe's and similar. Hopefully the problem is in the showerhead proper, and not in the valve.
Best 'o luck, --W/D--
Jul 24, 2009 | Delta & Single Handle Shower Faucet
Home Logo
52 people viewed this question
Top Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
