Question about Samsung Propel A767 Cell Phone
Screen says Please insert SIM card - Samsung Propel A767 Cell Phone
  • 457 Answers
A SIM card is a little chip, size of a thumb nail, used to identify yourself as a valid customer of a phone network. If you do not have one, you need to buy from a phone service provider first, your mobile does not allow you to make phone calls without one.
The SIM card must be installed in your phone, for the A767 you have to open the lid on the back, remove the battery and slide it into a slot in the upper left corner of the battery compartment. The contacts of the SIM should face down, the little triangular clipped off corner should be on the right, bottom side when you put it inside.
If you purchased a SIM before already, and installed it properly, it may got loose in its little hatch, e.g. by rough handling. Make sure the SIM card is properly in place (proper orientation and still all way in its slot).
The SIM card may also got dirty or liquid may have entered the phone case. In this case, remove the SIM, carefully clean it and the inside of your phone, reinstall and retry.
Posted on Oct 24, 2010
SOURCE:
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
My samsung tocco has full signal but screen shows sos calls
its because of sim card error please insert some other sim card and on it for at least 5 hour once mobile frequency clock will set to new sim card then re insert old sim card it will take effect 100 %
Dec 18, 2010 | Cell Phones
I have a samsung a707 and the message on the screen says "please insert SIM card, but the SIM card is already inserted
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.prounlocking.com/samsung-a707/rs8wp9/
Oct 29, 2010 | Samsung SGH-L700 Cell Phone
I have nokia 3120.problem is when i insert sim card.mobile screen show "please insert sim card" please find this problem.give me ans. In my e mail ID .thanks to you
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Oct 16, 2010 | Nokia 3120 Cellular Phone
I insert my sim card and on the screen it say no service.
You will have to get your phone unlocked to use any sim card in your phone.
There are many sites online that offer this service for about $3
Aug 05, 2009 | Cell Phones
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Sim card
HI,
please follow this link for instruction on how to insert sim into nokia 6111
http://nds1.nokia.com/phones/files/guides/Nokia_6111_UG_en.pdf
Jul 10, 2008 | Nokia 6111 Cellular Phone
Unlock sagem my w-8
Hello! I have similar situation with mobile. As a gift I resieved Sagem my W-8 from Italy. I insert ukrainian card n it write "sim is noy allowed".What to do?If u can please help me!
MY MOBILE IMEI NO:356794001608577.
PLEASE SEND ME THE UNLOCK CODE ON MY E-mail adress:[email protected]
thank U before
Svitlana from Ukraine
May 13, 2008 | Cell Phones
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Samsung Propel A767 Cell Phone Logo
155 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
