I have a dlink wireless router DI-624. I have a 2nd laptop that was once connected to my wireless network but received a virus, after cleaning up the virus now I'm unable to connect to my wireless network. The message I'm getting is "connected with limited access". It allows me to connect to the network but not the internet.
  • 1 more comment
  • louisbryant Oct 26, 2010
    I'm not sure how to reinstall the driver. Can you assist me with that?
  • louisbryant Oct 28, 2010
    Its a Compaq Presario Laptop...
  • louisbryant Oct 29, 2010
    I don't have the model number....do you think there could be a problem with my router?
    Genius:
  • 1,035 Answers
Hi. One of the driver file of your wireless adapter might be infected of the virus. These File might be deleted when you do the clean up. My recommendation is try reinstalling the driver of your wireless network card.
Posted on Oct 24, 2010
  • 1 more comment
  • Angelito Rabago
    Angelito Rabago Oct 26, 2010
    Sure no problem. what is the brand and model of your computer,
  • Angelito Rabago
    Angelito Rabago Oct 28, 2010
    do you have the model number?
  • Angelito Rabago
    Angelito Rabago Oct 29, 2010
    Hi. It is easy to identify if you router has a problem. Try using another computer and connect it to your router. If you will be geting tha same problem then there is a problem with the router. Now, inorder for you to check the computer.Try this steps:
    Go to the command prompt by clicking start menu then all programs then accessories
    type in ipconfig from the command box
    if you will be getting 169.x.x.x IP to your default gateway then this could be a hardware or software issue. Reinstalling the driver for your wireless will usually resolved the issue. If after reisnatllation then still you are etting the same 169.x.x.x IP address then, its a 100% sure that your wireless adapter is having the problem
6ya staff
SOURCE:
I cannot find my dlink network key to enable my laptop to the net
Your wireless network must be secured that is why you are now not able to connect to the wireless network. You will need to check the wireless settings of the router.
Do you have any computer connected to the router ?
If not then you will need to connect the computer to the router and open the set up page of the router. On this page you will find all the settings of the router. You will find the wireless network key also.
Apr 18, 2010 | D-Link DI 514 Wireless Router (DI-514)
I want to password protect my wireless network. I have a dlink 514 router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dec 02, 2009 | D-Link DI 514 Wireless Router (DI-514)
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
How to put a password on dlink dir-300 wireless network
u have to setup as wep
then enable secure network then set encryption key.wihc is prompt for connect network.
Dec 30, 2008 | D-Link DI 514 Wireless Router (DI-514)
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
DLink connection
  • try updating your D-Link's firmware at:http://support.dlink.com/products/view.asp?productid=DI%2D524
Jun 19, 2008 | D-Link AirPlus DI-524 Wireless Router
New lap top
Open a web browser and type http://192.168.0.1 in the address bar.
Enter admin for the username and no password to get into setup.
Setup your account.
Apr 22, 2008 | D-Link DI 514 Wireless Router (DI-514)
Open Questions:
Computers & Internet Logo
Ekse
Marvin
Marvin
