Question about Toshiba Satellite R10-S802TD Tablet PC
Toshiba R10 When I start my Toshiba R10 Tablet PC The tablet/pen function works perfectly up to the point a user logs on. Once logged on the function does not work.
  • chafol Jun 08, 2008
    I should have said it was working until recently. Thanks for the suggestion anyway
It might seem that the other user has a limited account and maybe the driver of the pen function is limited only to the administrator.
Rusty;
Hallel Computer Enterprise
baguio city philippines
Posted on Jun 08, 2008
What is the combination of keys (shortcut) to change the screen resolution (not orientation).
There is no Fn-Fx key combination to change screen resolution (at leat on my R10 running Windows XP. Even if you create a shortcut to open the graphics properties you still have to open the relevant tab manually to change resolutions.
You can open the Intel Extreme Graphics 2 for mobile icon on the tray, go to the graphic properties change the resolution and save as a scheme. With a customized scheme defined you will be able to click the Intel Graphic properties and select that scheme. But be careful, your tablet pen will no longer be calibrated with the available screen area.
I tried on my R10 (native resolution 1024x768) and all I could select was 800x600@ 60Hz.
Feb 23, 2011 | Toshiba Satellite R10 Tablet PC
I have a Toshiba Satellite R10 Model PSR10C-AN303E Laptop. I had lost the screen (went blank) last year. After googling I fixed the problem by opening the laptop and plugging backin the wires that came...
could be due to neighbours using WI Fi and interferring with your Wi- FI . Log into Wireless router and change the channel number from auto to the lowest channel number available plus 3 so it is different to all the people who use the auto channel mode.
Apr 04, 2017 | Toshiba Satellite R10 Tablet PC
Forgot password to enter xp
OK
RESET IT
YOU GO ON SAFE MODE AND CREATE A NEW ACCOUNT . TO GO IN SAFE MODE PRESS F8 BUTTON WHILE BOOTING WINDOWS. ONCE IN SAFE MODE CRATE A NEW ACCOUNT, THEN RESTART THE PC. ONCE YOU RESTART LOG ONTO THE NEWLY CREATED ACCOUNT AND GO:
CONTROL PANEL> ADMINISTRATIVE TOOLS> COMPUTER MANAGEMENT> ON LEFT SIDE SELECT LOCAL MANAGEMENT AND GROUP>THEN SELECT USERS>THEN U WILL SEE LIST OF USERS .
RIGHT CLICK THE USER U NEED TO RESET PASSWORD THEN SELECT ALL TASK SET PASSWORD>CLICK PROCEED> THEN LEAVE NEW PASSWORD AND CONFIRM PASSWORD BLANK THATS ALL
Nov 13, 2009 | Toshiba Satellite R10-S802TD Tablet PC
How to enable the touch screen on my toshiba satelite r10
you need the wacom touch screen driver, just go to wacom .com and all i did was download and installed the driver, i run win xp , not tablet version, and after the driver ws installed the table an pen worked 100%,
Sep 28, 2009 | Toshiba PA3317U-1ETC - Satellite R10, R15,...
I need to change the tip of the stylus
I own a Toshiba Tablet PC that uses a wacom stylus.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip.
Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside.
Press gently but firmly to make sure it is holding.
Hope it helps.
Aug 17, 2009 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Setting up a laptop to use its tablet pc functions
XP Pro should run fine on it - I would assume that is what it came with. You may need to download additional drivers from Toshiba. I would check with Toshiba about the pen as well, but without it should still function as a regular laptop.
May 13, 2009 | Toshiba Satellite R15-S822 Tablet PC
My Wacom Bamboo Tablet Pen: only the pen was dropped. Now the eraser works but the pen tip does not. Neither do the buttons. The tablet itself does not pick up the pen tip's presence, but it works perfect...
Try replacing the pen nib. Take out the little nib with a tweezer or something along those lines and replace it with a new one. There should be a few of them when you bought the tablet. Also, try looking at the tablet properties.
Feb 02, 2009 | Toshiba Portege M200 Tablet PC
Clean dust from tablet pc screen
I have an R10 tablet.
I once asked a Toshiba certified technician if I could remove the screen cover and I was told that I am not supposed to do that.
Maybe you shoul take the unit to a Toshiba repair center in your town, or country.
Hope it helps.
Jan 20, 2009 | Toshiba Satellite R15 Tablet PC
Take apart instructions
This sites a good one.  If you can't find what you need, let me know
http://www.laptoprepair101.com/
Oct 04, 2008 | Toshiba PA3317U-1ETC - Satellite R10, R15,...
Problem with my tablet pc
Hi
The Satellite R10-S802TD doesn't have built in bluetooth device, however it's bluetooth compatible. any external bluetooth adapter will work. Toshiba recommends
PA3370U-1BTM Toshiba Bluetooth SD Card V1.2 or
PA3405U-1BTM Toshiba Bluetooth USB adapter as indicated you product's spec sheet.
Please post if you need further assistance.
Good Luck
Feb 06, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
252 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
