Question about Sony Radio Communications
Covers for earpieces - Sony Radio Communications
  • 943 Answers
You can go to ebay and purchase some if that is what you need
Posted on Oct 24, 2010
SOURCE:
On my blackberry curve, and i cant hear anyone on the phone but they say they can here me.how do i fix this?
It can be earpiece problem when you can not hear the person you are calling,when the phone experience dropping on the ground,sometime it can be fix by realigning the earpiece connector in proper position which the terminal or interface were dislocated on the board or pcb,dismantle the screws at the back and lift up the front cover,then you see the earpiece attaching the frame of the lcd screen located on the upper portion,you can now start working with it,but if this method does not work,you need to replace a new earpiece,hope you can look for any supplier that sell spare parts,otherwise bring it to the service center for parts replacement.
Sep 22, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
I cant here the caller voice properly in sony p1i mobile.
check the volume keys if working and into the max level
check and unscrew all sides of the mobile,there are some hidden screws attach so be carefull of doing it.
you will see the earpiece on top cover,try to clean the boad surface as well as re-align the pin of the earpiece....
Jun 07, 2011 | Sony Ericsson P1i
When I get a call, I cannot hear anything from the other side without speakers on. Also my playback failed with "No media file found"
Your listen/speaker/media device has a problem,probably destroyed/damaged through excessive dust particles or either exposure to some form of liquid. solution is to change your speaker phone.
Dec 20, 2010 | Sony Ericsson W760i Cellular Phone
Nokia 1208 earpiece problem
Hi, Earpiece can get damaged if there is dirt or the earpiece is totally damaged.
You can clean up the earpiece and see if it will work, if it doesn't work, you will need to replace it.
Thanks for using fixya.
Sep 30, 2010 | Nokia 1208 Cellular Phone
My l6 fell and now the screen is blank what should I do
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Jun 18, 2010 | Motorola Mobility L6 Cellular Phone
Nokia 6233 - Earpiece Problem (No Sound)
ok first of all you should open your mobile and claen it carefuly.then re pack it care fully.thats it if problem not away then tell agian me i have seen tha pic also but it is for the tecnicians if mobiles.ie mobile repairer
Apr 03, 2010 | Nokia 6233 Cellular Phone
My n70. when i received a call there's no sound or dial?
Replace the inbuilt earpiece. Many Nokia earpieces are identical and readily available.
Remove Battery.
Remove the front cover. Prise out the earpiece from the back of the casing. Replace with new one. clean contacts on motherboard with isopropyl alcohol. Reassemble.
If this does not work the sound IC on the board is most likely damaged and you will need to sent it to a repair shop.
Hope this helps
Jan 26, 2009 | Nokia N70 Cellular Phone
I evidently dropped my Motorola H700 Earpiece and lost Mic Cover
as far as I know yu have to buy a new one but if you do find out that you can just buy the mic. please let me know
Dec 08, 2008 | Motorola Mobility H700 Wireless Headset
Razr
I have the same problem with my pebl which occured when i had a replacement cover fitted. I believe there should be a copper wire attached to the earpiece inside which has gone missing during the process. as of yet unsure where to attach the new one.
Aug 05, 2007 | Motorola Mobility RAZR V3
Radio Communications Logo
138 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Anthony Ward
Anthony Ward
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
