Question about D-Link Computers & Internet
Hello...I'm trying to connect a wireless kodak printer and I do not know my ssid to enter into the key pad and a wireless connection cannot be completed without it.I have a d-link router.thanks....Andrew
    Master:
  • 515 Answers
You can open the admin page of the dlink router to set up the SSID in the wireless section. To do that, you will need to connect a PC to it and set up an IP address for the PC in the same subnet of the admin IP address of the router. You may see the admin IP address on the back or the bottom of the router or from the manual or from the web site of the manufacturer. If the admin IP is 192.168.0.1, you can set up the IP address of your PC in the TCP/IP properties to use a static IP such as 192.168.0.10 or something and open the admin page of the router in a web browser by using the admin IP address of the router as the URL. Then you can login there and change the setting. After you get the SSID and maybe WPA password set, you can use it for wireless connection on your home network.
Posted on Oct 24, 2010
SOURCE:
I dont know what where to find out my ssid for connecting my wireless printer to my pc i dont have no kind of manual so cant refer to that please help
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.
Jan 30, 2012 | HP Office Equipment & Supplies
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
Changed modems from motorola to a cisco for faser internet. Printer will not link up. It can see the modem and pin has been entered. no connection!
Is the printer is connecting wirelessly, the you may need to redefine it on the printer. There are two possibilities :
If there is a key defined, make sure your printer has the correct key (aka passphrase) defined on it.
If there is no key and it is an Open SSID, then you can go for FACTORY DEFUALT settings on the printer if it not an issue and again configure the settings on the printer.
Also a power cycle can help the printer to re-associate with the new CISCO AP.
Mar 12, 2011 | Kodak ESP5250 All-In-One InkJet Printer
I am trying to set up a wireless printer connection. I need to know my SSID and Network key. How do I find this information?
the SSID is the name of your home network. if you dont have a wireless network the printer might not function adhoc. the network key is the password used to connect to your wireless. some devices have the ssid and key listed on the bottom of the router.
Mar 07, 2011 | Office Equipment & Supplies
I would like to know what an ssid is as i am trying to connect a ds to the internet, i have the wep key
the SSID is the name of a wireless network so it is easier to recognize. If you want to make things easy for you to connect to your wireless home network to access the internet with your DS Lite, go to your router configuration. Make sure that the SSID is set to be broadcast or visible. Make the SSID an easy name that you will remember, yet that is not too personal since everyone will be able to see it.
Then start your Nintendo DS and go to the wireless connection configuration. It will start looking for broadcast SSID and will eventually find the one of your network and list it. Select it, enter the WEP when prompted and save the connection.
You should be able to enjoy your internet connection from the DS after that.
Let me know if you encounter any issue.
Regards,
Jan 11, 2011 | Nintendo DS Lite Console
I dont know how to change the SSID Name and WEP Key.
You have to change it in the printer settings, not in the router! Otherwise you'll lose connectivity in all the other computers that use this router.
The SSID is the name you gave to your wireless network, and the WEP key is the password you set for your wireless connection.
Oct 28, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How do i do a wireless connection between computer and a kodac 5100 all in one printer
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf
follow this manual ...
  1. Check the Wi-Fi Status Indicator on the front of the printer:
  2. Status: Do the following: Off
    1. Select Menu (or Home)>Network Settings and press OK.
    2. Select Turn Wi-Fi Radio On and press OK.
    3. Select Wi-Fi Setup Wizard and press OK.
    4. Select the SSID (name) for your router.
    5. If you have your network secured, you must also enter your password.
    Blinking
    2. Select Wi-Fi Setup Wizard and press OK.
    3. Select the SSID (name) for your router.
    4. If you have your network secured, you must also enter your password.
    5. NOTE: If the message Your printer is already configured for Wi-Fi network appears, your printer cannot find your router.
    6. If this occurs, check that the router is turned on and located within 100 ft (approximately 30 m) of the printer.
    On The WiFi Status Indicator could be on, but you could be connected to the wrong router if you used the manufacturer's default SSID and password when you set up your router. If this is the case:
  3. Select Menu (or Home) from the printer control panel on the front of your printer.
  4. Select Network Settings and press OK.
  5. Select View Network Configuration and press OK.
Place the KODAK All-in-One Printer Software CD into the CD-ROM drive on your computer.
Follow the on-screen instructions. Do one of the following depending on the version of KODAK All-in-One Home Center Software:
  • When the KODAK Printer Setup Utility screen appears, select how you want your printer to be connected:
    • USB cable
    • Wireless Wi-Fi® connection
    • Ethernet cable
Oct 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
What is a ssid and a wep key. I am dumb.
SSID is the wireless networks name you want to access.
WEP is a special hexadecimal key to secure your network means if you want to connect a wireless network you will have to put this key.
It will be provided by the admin
Aug 12, 2009 | Office Equipment & Supplies
SSID - computer cannot find the printer
You need the new driver, download from Kodak.
Vitally
Jan 11, 2009 | Kodak EasyShare EX1011 Digital Picture...
Cant browse at a particular place
hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
  11. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Jun 24, 2008 | Dell 430-0008 Network Adapter
Open Questions:
Computers & Internet Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
