Question about Panasonic Televison & Video
Well so far it isn't looking good from what I've seen. But my cable outlet was pulled off the back of my TV by accident. I was just wondering if there was a way to sauder it back on? It's a Panasonic TV. Thanks
  • 2 more comments
  • cmonesbiz Jun 08, 2008
    Hi it's a 4 head stereo tv about 10 years old I'm not sure of the model number
    okay here it is pv-m2o47 thanks
    well I stil get ch. 4,5,7,9, and 11. The volume still works too
  • cmonesbiz Jun 09, 2008
    I'm back, and if you forgot from last night... My cable outlet was pulled off the back of my TV by accident. I was just wondering if there was a way to sauder it back on? It's a Panasonic TV. ThanksWell I have the TV apart. I'm still not sure about the connection. It's in another guys room, and he's not home. But the model number was right. PV-2047 from Sept. 97 was the model number. There just doesn't seem like anything to connect anything to for input, or ground... Thanks
  • Panasonic Master
  • 8,617 Answers
Whats the model number of your panasonic? I may be able to help you.
Posted on Jun 08, 2008
  • Sonny Berry
    Sonny Berry Jun 08, 2008
    I am sorry i am not finding any info for that model number. If the Coax connector isnt destroyed you may be able to solder it back it will only have two connections one for input and the other as a ground.
Asus k52f laptop hdmi port no sound
Step 1:
Plug your TV into the HDMI port.
Step 2:
Right click on the audio icon on the task bar, and the click "Playback devices".
Step 3:
Choose your TV and click "Set default"
Feb 21, 2013 | ASUS K52F-BBR9 Notebook
Have a 2000 GMC Yukon Denali. Won't fire.
Make sure that the belt isn't extremely tight and they the belt tensioner isn't liked up by pulling in the belt. It should move and spring right back. Make sure engine isn't locked up. And please explain what happen with the vehicle. The fact that you replace plugs and wires and fuel filter for a car that's not turning is throwing me off. So right now we are going all over the place. But definite look at belt and tensioner I've seen a few times that a bad tensioner will make the belt wrap around tighter inhibiting the engine from turning.
Jun 26, 2012 | GMC Yukon Denali Cars & Trucks
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
Audio isn't working
ya know I hate to say it but I've done this before. check the mute button on your remote. I've accidently hit mine before and it took me several days to realize it. lol. if it's not that. check the volume of the set itself, then check the volume with the remote....I know these are weird things to check, but they do & have happened, to me. lol. good luck & God bless.
Mar 21, 2012 | LG Televison & Video
I got a sony bravia kdl46nx800 led tv and for some reason, there is a green line on the right edge of the screen on certain HD channels and not on regular channels when i watch the shows. it is a common...
Hi, I can't say I've ever seen that happen with that TV before so I'd say it definitely isn't common. I'm pretty sure it's the signal from the HD channels, I'd suggest talking to your cable service provider.
May 14, 2011 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
The only way to shift the transmission into any gear is by holding the shift lever down or up, then releasing the clutch. It then stays in gear. If i just shift (this was working previously) then release...
It sounds like your shifter pawl is broken. It's trying to roll the shifter drum but it's not rolling it quite far enough for the drum to index to the next detent. It is rolling it far enough to put out the neutral indicator light. If this is the problem, a teardown of the transmission is required to repair this.
There is one other possibility. From the foot shift lever, follow the shifter rod back to the shift lever on the transmission. This is the shift lever that connects to the shifter pawl shaft. I"ve seen lots of them get worn to the point that they feel like they are going to fall off. When they get like that, they don't shift well. To repair this, you will have to pull the complete primary to get to it. If the splines on the shaft are worn badly enough, you're back to pulling down the transmission to replace the shifter pawl shaft.
Good luck
Steve
Aug 14, 2010 | 2002 Harley Davidson FLHTCUI Electra Glide...
Tv interference
Do you have a baby monitor or cordless phone or even a cell phone plugged into the same or close outlet...any such thing can cause interference.
Feb 11, 2008 | Goodmans 2065TS 20" TV
Toshiba CF36H50 turn
your problem is intermittent but from your complain it seems that your IF video circuit which is vry technical have your set checked by a technician.to resolve your problem the job will cost about $90.00
Feb 14, 2007 | Toshiba CF36H50 36" TV
Televison & Video Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
