Question about Exercise & Fitness
My horizon treadmill belt has started breaking from the edges. How do I repair it
    New Friend:
  • 14 Answers
Horizon Fitness sells replacement belts. There is no good way to repair a walking belt as they are a bit special, made to glide across a waxed or oiled deck.
Posted on Oct 25, 2010
SOURCE:
How do I oil the belt on on an horizon ct5.4 treadmill?
Hi
When I oiled my Reebok Z9 treadmill the silicon liquid that I purchased came with a syringe and a tube attached
You simply pulled the belt up slightly inserted the tube and squirted the solution toward the middle of the belt then repeat the process on the opposite side then turn on the treadmill and walk on it moving your feet from the middle of the belt to the outer edges
I hope this helps Nick
Apr 12, 2018 | Exercise & Fitness
Ticking sound on horizon t101 treadmill
If you wish to get some details about treadmill repair; visit the site linked here. in the search tab put the world "ticking" and search.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Horizon Exercise & Fitness
Horizon T74 Treadmill powers on, programs and incline work, belt does not move and no sound from motor. What do I check?
Hi there, ....Sounds like a lower board issue. You can contact jatinahATrocketmailDOTcom for repairs on this style of unit. Good Luck!
Dec 07, 2016 | Horizon Exercise & Fitness
The belt won't start on my treadmill. the speed is already at 0.5 when you turn it on instead of zero. everything starts going and speed can be increased but belt doesn't move......
Hi there, I think I can help. Now depending on model year the Horizon T500 can use a couple different motor control boards, most all of which are fixed at jatinah electronics which you can find with a Google search. It sounds like a failed control board fixed for 99 or less and exchanges available with returned cores. Good luck
Feb 04, 2015 | Horizon T500 Treadmill Walking Belt
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
Hi i have horizon treadmill t401 i don't when i start it 3 miles for hours for my workout it stoped and restart very fast i don't no what to do can u tell me how to solved the problems please
1)this a problem by lack of maintenance schedule. LUBE the deck belt, probably you have a worn deck belt.
2) Lube the rollers bearings too , inmediately.
3) measure the input voltage motor in the terminal, if there are the motor need repair.
4) measure the output voltage board, if there are NOT the board is faulty.
se the block diagram. attached. see my personal TIPS
God bless you
Oct 07, 2012 | Horizon T401 Treadmill Walking Belt
I have a horizon t73. Best treadmill ever but it now wont start. It turns on, electrical works, sounds like it going to run but the belt doesnt move. any ideas?
Dear Sir:
1) Tight the deck belt see the diagram 2) Lube the deck belt in according with the instruction manual maintenance. 3) Test the drive belt and replace it 4) Measure the input voltage for the main motor if there are the motor need repair or replace 5) Test the output voltage from the main motor board if there are NOT the board is faulty.
Apr 29, 2012 | Horizon Fitness T73 Treadmill - $1,299...
LOOKING TO BUY A MAGNETIC KEY WITH BELT CLIP FOR MY HORIZON RTS5.6 TREADMILL
Contact Horizon Fitness at 1-800-244-4192 for customer service.
Parts can also be obtained from the Treadmill Dr., and Fitness Repair Parts..
Dec 15, 2010 | Horizon Safety Magnet Key, Rope/beltclip-
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Exercise & Fitness Logo
134 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
