Question about ASUS A7V400-MX Motherboard
No video hello sir i am having a problem when i reboot my monitor goes to sleep mode and my key board doesnt light up what do i do please help
  • 31 Answers
After the reboot is your motherboard and other pc parts like cpu fan still working? might be a faulty powersupply
Posted on Jun 09, 2008
Hit start Alienware computer goest to alien head on screen then straight to sleep mode. Please read
When you say computer clock do you mean the LED read out on the mother board? if so the numbers you are seeing are error codes you will need the mother board manual to know what those codes mean. If you don't have the manual it's possible you can go to the mother board manufacturers web site and download one then you can look up the codes to see what the problems are. Hope this helps
Jul 26, 2012 | Alienware PC Systems Computers & Internet
Monitor stuck in safe power mode
"Power Save Mode" but it tells you to press a key or whatever?
were you able to reboot the PC?
if you can reboot the PC but no screen is showing up during Windows load (you can see the hard drive activity LED lighting up and your hard drive spinning), then, youre probably have a broken monitor.
Or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep. http://www.ezsystemrepairs.com/
Jul 01, 2012 | Dell Computers & Internet
Power on and monitor goes to sleep mode
You need to try it on another PC, alos verify if the VGA cable is good. If nothing change, then you need to open it up, first thing to look for are the capacitors in the power supply. Look for cpas with bulging top/seal, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 19, 2010 | Acer AL2216W LCD Monitor
Sleeps and won't wake up. unblug pwr supply won't shut down properly. when pwr supply is plugged back in, monitor like comes on blue then amber like in sleep mode. Nothing shows on monitor. ctrl /alt/del...
Hello
Thank you for using FixYa for your problem
Needs a techie toolkit disc to run HDD regeneration scan then try the repair mode in your install disc, (2nd repair mode)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Gateway GT5625E Refurbished Intel Desktop...
My monitor goes to sleep and doesn't come back on.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then go to display property and set screen resolution to 1024*768 then apply and ok.
if still not work then try safe mode then uninstall graphic driver and reinstall.
When you power up the computer press F8 key untill you see windows logo.
Let me know if you need further assistance.
Thanks for using Fixya.
Feb 07, 2010 | HP w1907 LCD Monitor
Computer powers up but monitor goes right to sleep?
when i power start my computer,,the light come on and seems to operate but the monitor doesn't come on,,,when switichin the monitor off and on , the blue light comes on and it reads monitor goin to sleep and the screen gets dark,,but the monitor orange light is on,,,pls help
Sep 21, 2009 | HP Pavilion MX70 17" CRT Monitor
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
Monitor goes to sleep and won't wake up
You can google search for an app called NOSLEEP.EXE
It was written by a Symantec employee to keep your screen active regardless of pic settings.
Install and run it. That will verify the issue is with of or monitor
Software is free
Apr 09, 2017 | Mag Innovision LT776s 17" LCD Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor doesn't work
I'd try this monitor on a spare computer. It sounds like the video card (motherboard integrated or otherwise)is not putting out any video information or missing sync signals. The monitor must receive these signals or it will go into standy/sleep mode. If the computer has integrated (on motherboard) video, check your bios settings to see if it is properly enabled. If it has a slot video board, then try a different video board. Your present board might be dead. Another possibility is a bad cable connection. check the connectors for bent pins. Assuming the connector is the standard HDB-15, it is easy to bend a pin over.
May 30, 2007 | LG L1730S 17" LCD Monitor
ASUS A7V400-MX Motherboard Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
