Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Stopped freezing and hear a clicking sound going on and off
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
Freeze keeps clicking over but wont freeze was in storage frooze for 1 day wont freeze has it run out of gas or would the timer need placing what would be the problem worth reparing
If you are hearing the clicking sound down by the compressor you could have issue with the compressor. Really need more info.
Oct 30, 2014 | Freezers
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
The refrigerator often freeze food at the rear of fridge. Have a buzzing sound follow by a click which last for a few seconds. The bottom freezer stopped working, started again and is not freezing now
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 11, 2010 | Amana ARB1917CSR Bottom Freezer...
My 1998 range rover was overheating so i pulled over and took over the cap. anti freeze got on the engine i dont know if it wet the wires.soon after my radio and my ac stopped working.I hear a clicking in...
Sounds not good. Disconnect the negative battery terminal, and flush EVERYWHERE with clean water (hose okay) antifreeze will never dry or go away....let it all dry and try again.
Aug 15, 2010 | 1998 Land Rover Range Rover
Clicking sound in computer then BSOD
There are very few mechanical parts in cpu...some of them are cpu fan. smps fan chassis fan hard disk motor or cd drive.......as you were talking about click...i doubt on cpu fan also clean the processor and coolant as there might be dust in it that prevent the cpu fan to cool down processor this might be causing system freeze....do reply back if this solves your prob
Oct 01, 2009 | HP Media Center m1270n (PP132AA#ABA) PC...
I no longer hear the clicking sound when I click
Relax, nothing wrong....
click is simply a user's preference.
Old old keyboards used to click all by themselves. Now the keyboard uses the onboard speaker to do its clicking.
Go to "Sounds" in the [Control Panel] and un-mute the speaker.
I prefer no sound...
Sep 25, 2009 | Computers & Internet
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
