Question about Dryers
I need the rear panel hook up diagram for connecting av1 av2 and hdmi plugs to my philips 50 inch plasma model pf9956/37. in addition my whirlpool duet dryer in not operating. the status red light is on indicating "control locked" and I do not know how or why.
How do I hook up a dvd player
yellow, white and red wires usually connected to the same name same colors on both devices.
Does the tv need to be on a certain channel? YES, try change to all ex: VIDEO 1, VIDEO 2, DIGITAL, ANALOG, HDMI or any according to tv sysem
Oct 27, 2013 | Seiki Digita Seiki LC46G82 46 in. LCD HDTV...
My p.s3 will not work on my 42 inch plasma t.v.i used to use an hdmi cable to watch it now im using a.v cords how do i reset or fix the settings it was on before?
Go to the main menu of your tv then try to select for the video input, you will see there the inputs tv or av1,av2, hdmi1,hdmi2 etc. try to choose the av1 or av2.
May 14, 2011 | Televison & Video
Have satelite as AV1, Wii as AV2 - hooked DVD player up as component 1 using RCA plugs but it is only black and white and very grainy.
Connect the yellow RCA jack, which is actually called composite video, not component, to the DVD. If it's component, it's the wrong jack and you'll need the additional 4 cables to satisfy a component connection for HDTV.
Dec 23, 2010 | LG 32LG30 32 in. LCD HDTV
Hdmi input
the best is a AV1,AV2 input as compatible input for non dedicated devices, as VCR, DVD,...
Dec 22, 2009 | Hitachi 57F510 57" Rear Projection...
VP50HDTV10A
hi i have a 50" plasma HP50TV10A and just show half of the tv picture horizontal
Jun 18, 2009 | Vizio VP50 10A 50 in. Plasma TV
How do I hook up my digtl cable and dvd to my Vp422 vizio tv
Surround Sound to 8 or 9 8 is best
DVD to HDMI 1
Direct TV to 10
If you have these connections on your peripherals, this is recommended..
May 12, 2009 | Vizio VP422 42 in. Plasma TV
Input Problem
Mine was the same, except i also could not access HD Components.
Unfortunately i had to get some one in, as the circuit board at the back of the tv was burnt out.You might have to get a technician in to service and replace the burnt circuit board.
Jan 16, 2009 | LG 50PX5D 50 in. Plasma HDTV
Philips magnavox plasma tv model 42mf7010/17
Turn off the video mute if it has this setting. Try using a VCR tuner and connect the VCR to the TV on AV1 or AV2 inputs. THis fix is free until Feb. 09. After that, you will need a DTV converter box or pay for a cable/sat box.
Jul 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
Cant see Picture
Nope. The AV inputs except a composite video signal that is either NTSC or PAL. You will need to convert the PAL signal to NTSC.
Dan
May 09, 2008 | Philips 50PF7220A Television
Philips 50 inch Plasma - no audio on occasion
Try swapping the HDMI cable. They occassionally fail.
Nov 21, 2007 | Philips 50PF9630A 50 in. Plasma Television
Dryers Logo
Top Dryers Experts
Marvin
Marvin
paul
paul
