Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 can't read CD
When I insert DVD, the screen come out say that no CD, or bad CD etc. and can't display. I do not know what is caused this problem, since It works well before. Please help and teach me how I can fix it.
Thank you for your time and attention. I am looking forward to hearing from you as soon as possible.
  • 7 more comments
  • Takusan Jun 08, 2008
    Today I tried again to see if it work but t became entirely nothing work even I try to turn on power, and see nothing come out on TV screen, and light is still keeping on red. Those things of problem and truble to let me dubt that Cyberhome CH-DVD 300 is certainly not a good product. I am regreting that I bought this bad product of Cyberhome CH-DVD 300. Help, please.
  • Takusan Jun 15, 2008
    Cyberhome CH-DVD 300 has no service available, and also has no web site of cyberhome, so I dare said that cyberhome CH-DVD 300 is a bad one,just seling and no sevice is available even manufactory service. I am so regreting that I bought this non after service products. so that is why I posted the problem at FIXYA for helping. could you help how to fix it?
  • Anonymous Jun 18, 2008
    I will put the dvd or cd in and it says insert disc.
  • nfeeny Jul 04, 2008
    The LED stays red, indicating it is in standby mode. I cannot get it to turn green, indicating power on. I cannot get it to open or close. The TV says "no disk", even when there is a disk inserted, indicating that it can't read the DVD. I tried unplugging the unit with the hope that it would reset itself, but that didn't help. I tried the buttons on the front of the unit, just in case the battery in the remote control is bad, but that didn't help. According to what I have read, CyberHome doesn't have a website and doesn't offer any technical support.
  • r2b2030 Aug 18, 2008
    I too have the same problem.Tried unplugging,sometimes slamming my fist down on top of it helped it to stop loading and play finally,but then the audio would not come on.It reads loading,no disc or bad disc.It used to play my cds too now it does not want to play anything.The weird thing is I would buy another,but nobody seems to be selling the thing,probably because of its short life span.Now where can I recycle this thing?!
  • Takusan Oct 08, 2008
    I had been throw away this bad products in the world even it is selling in USA. It is really ashamed of selling in USA as USA products.
  • dsmatlock Oct 18, 2008
    The DVD player is not reading any DVDs.
  • Anonymous Oct 22, 2008
    same problem
  • Anonymous Nov 03, 2008
    Same problem, opened it up and it seems that the spinning is so much the problem as is the laser not reading the disc. Which in turn makes it not spin because there is no need... or so it thinks.
Check C10 (2200uf/10v) &C11 (1000uf/10v) in power supply board.I had the same problem ( bad disc),both these capacitors were low in value.
Posted on Oct 04, 2009
Change the disc motor
Posted on Oct 07, 2008
Mine had the same problem. I took off the casing and discovered that the disc simply wasn't spinning. I spun it once with my finger, and it took off. Problem solved. It's not elegant, and the DVD player is bound to get dirty without the case on it, but it'll do until I get another one.
Posted on Aug 21, 2008
I have the same problem with the unit saying 'bad disc' or simply getting stuck in 'loading' mode, even for regular movie dvds. My unit is only three years old - I can't believe the reliability is so bad. I have found, however, if I just keep opening and loading it, after 5 or 6 times it will finally work. If you have the patience for this, at least you can watch your movie!
  • 29 Answers
Why don't you call manufacture and see if can get service.
Posted on Jun 14, 2008
2 Suggested Answers
BFixed
  • 104 Answers
SOURCE: Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Posted on Jun 08, 2008
MY CYBERHOME DVD PLAYER IS READING INSERT DISC AT ALL TIMES AND WILL NOT PLAY ANT DISC. HOW TO RESET CYBERHOME 300 DVD PLYER?
I am sure problem on Laser,may be it does not read any disk.So all times it say insert disk.You can better opportunity replace this damage laser.
Aug 10, 2010 | Cyberhome CH-DVD 300 DVD Player
My CyberHome DVD 300 says "bad disk" every time I load a dvd.
pls check ur dvd player optial pickup lense.try to clean or replace.
Dec 28, 2009 | Cyberhome CH-DVD 300 DVD Player
THE PLAYER DISPLAYS BAD DISC.
You have not said the TYPE of CD or DVD you are trying to play.
Your manual will clearly state what can be played and what cannot. ALSO, some mfg's like mine (samsung blu-ray) provided software or firmware updates you can d/l to flash drive or burn on cd and insert.
Check manual and your mfg websit for what's available.
May 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 dvd player does'nt read any dvd
I have CH DVD 300 Model, i have purchased this DVD on 2007, yestarday (17/05/2009).
When i put DVD in, i cannot see any screen on TV, perviosly i can seen default screen CYBERHOME, all other things are ok, (powe on ok, eject & incert ok,) dvd is not playing after putting DVD in CYBERHOME.
pL. give solution on my mail Email ID: shankarg@iss-global.com, gudala2000@gmail.com
at the earliest.
With Regards
Gowri Shanker
India
May 16, 2009 | Cyberhome CH-DVD 300 DVD Player
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
548 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
