Replaced main circut board due to wouldnt even turn on, now the dial with the lights is all lit up will not allow meto select a prefered load style whats wrong with it now we were very carefull replacing the circt board
The Piezo control board opens the gas valve while it makes a spark. Once the flame is lit the milivolt flame sensor holds it open from there on. Replace the piezo control board to fix.
Turn off power to the dishwasher at the circuit breaker box. Take apart the Dishwasher door and unhook the cable from the User Interface panel to the main control board. Then, turn the power back on and close the dishwasher door so it latches. The drain pump should go on. If it doesn't the main board is bad. If it does, it's the user interface panel.
On some gas valves the pilot setting is on the same dial as pilot on and on .on others the pilot light has aseperate button on right side of control dial. If yours has this there will be a cut out on cotrol dial that must be aligned with button to allow it to be depressed to light pilot. If yours has this align control dial cutout with pilot button,depress button and light pilot,hold for about one min. and slowly release,if pilot light stays lit,turn down thermostat and rotate control dial normally to right . There should be arrows or marks on dial and gas valve to line up. If pilot light stays lit turn dial to next position and check to see that pilot is still lit. This should be on position, turn up thermostat and burner should light. If your dial has pilot light setting on it then rotate dial to each position,try to depress dial and when you have right one dial will depress allowing you to light pilot. Follow same procedure as above and you should be in business. Hope this helps.Thank you
hi mate,just follow these instructions
1. make sure to have 2 sims in phone(do not use 3g sims)
2. make sure wlan is disabled
3. enter engineer mode (type in *#3646633#
4.scroll up not down to number 10 RF test tool
5.choose gsm touch ok verify ok touch power scan
6.select band dcs 1800 press ok
phone will go to test looking for DES(frequencies)
wait until phone crashes or seems inactive(can take 3 to 15 min)
press the end button (red one)
phones with one middle button use that one
phone will go off
turn on phone and it will be reset to
flight mode....(you can try to make call to verify,phone wil say cannot
make call,not, not allowed to dial like before)
go to settings and network setup,sim1 network setup,prefered mode and
select gsm prefered...(phone will now change mode unlike before
saying unfinnished)
try the phone to make a call (should be no prob now)
not finnished though ....
go into settings again select restore factory settings (password 1122)
wait for phone to restart...now its all done .....now you can change
your tones and turn wlan on etc
do not for any reason select wlan only or gsm only again...
Make sure there's power getting to the washer. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power. Sometimes the power cord disconnects at the washer, if this is
the case, the wiring must be repaired or replaced.
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
if yours has the control board mounted in back of machine, is there a red led lit on it? this indicates operation of main board. if lit then replace user interface.
