Question about Sony DSC-T2 Digital Camera
The power is not working correctly on my Sony DSC-T2. I.e. despite the battery being fully charged the green light flashes on briefly but the camera does not power up. This means i cannot get the pictures off the memory in the camera. I have bought another DSC-T2 from e bay so could change parts. Could you advise as to how i can get my photos off the old camera. Thanks
  • 10,594 Answers
It seems camera main board got problem and main board repairing requires high expertise level, related service manual level-3 copy in hand and very scpeail tools to remove/ install SMD parts on SY-180 main board of this camera. It is not even possible for normal camera tech to replace parts on camera board.
Are you highly experienced camera tech to provide you more info?
I'm afraid, you can not retrieve pictures from dead camera internal memory by replacing few parts on main board because it is not possible for an average person.
Similar DSC-T2 from ebay wont help you to get pictures from old defective camera memory.
May be you dislike/ disagree my answer but have to tell you facts because I'm Sony qualified camera tech and know what I'm saying.
Thanks.
Posted on Oct 24, 2010
SOURCE:
Flash not working
Can be for severe; reasons.
1. There is enough light.
2. You can force the flash, with the mode switch to Flash forced on, Slow synchro and Flash forced off. Try flash forced on.
3. The battery is not fully charged. When there is not enough power in the battery, the flash can't be charged enough to fire. But if the camera tries to charge the flash, a symbol with a lightening arrow and a dot is displayed. So if you see these symbols, could be you need better batteries. Try charging the battery.
4. the flash is really defect. Could happen too, but first check if everything from 1 to 3 is as it should be. only than you have to visit the repair shop or Sony if it is still in warranty.
Nov 30, 2013 | Sony Cybershot DSC-S950 Digital Camera
Camera won't turn on
this is happening when the batteries are not well charged or if they are normal batteries they are not powerfull enough to open it ..so ..you will need wither a new battery that holds the power well ..or if uses like I said normal batteries..buy a few good alkaline ones and try to power it ...cause those cameras are sensitive when it gets to power and amperage ..so it need real good batteries..not cheap ones cause those will not power it ..but just came up says battery low ..and shut down ..Ive been there with a simple Lumix(panasonic) and had the same problem ...since I use only duracell it work s..
May 29, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
My camera wont switch on
Make sure or Check out following thing :-
1) Direction of your battery might be wrong, Check out and put it again.
2) Load new or fully charged battery.
3) clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
4) Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix A345 Digital Camera
My sony cybershot dcs-s700, it has new batteries, but the power button flashes green and camera will not stay on, and you are unable to magnify. Whats wrong
Hi!
Remove the Battery from the Camera and clean the battery compartment using a soft cloth. Then, press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery is fully charged. If the issue persists then the issue may be related to mechanical failure and service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
After leaving my Sony DSC-T2 camera unused for only a couple of days the battery was flat. I recharged it fully but again it only lasted a day or two. I assumed the battery was dead and I purchased a new...
If the troubleshooting section in the back of the user guide doesn't help, I sugget getting in touch with Sony and asking them if it's normal, the only thing I can suggest in the meantime, is taking the battery out while it's not in use, or recharge it a few hours before you're due to use it. Phones get like it after a few years and with technology advancing the way it is these days, you'd expect a battery life lasting longer than a week, not a day.
Things to consider:
1. When it's off, is it off or left on standby?
2. Where did you buy both the camera and batteries from?
3. When you charge it up, do you charge it up with a half charged battery or a totally dead battery?
Jul 20, 2009 | Sony Cyber-shot DSC-T2 Digital Camera
Sony DSC-T2 lost flash feature
take it to the near service station you circuit belt insde is came out due to vibration or must be fall
Jun 07, 2017 | Sony DSC-T2 Digital Camera
Power inicator on DSC-H1
sound like a electronic problem, i would suggest to take in for service.
Dec 02, 2007 | Sony Cyber-Shot DSC-H1 Digital Camera
Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Jun 21, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Sony DSC-T2 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
