Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water acculation in refridgerator.
Water on trays at all levels. Have set a tupperware dish and it will fill in 1 week. dish is set near the rear , just right of the vent. Also under the slide tray in the freezer it fills with water and freezes 1/4" deep, front to back.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 114 Answers
I had a similar problem with my old hotpoint frig (top freezer, bottom frig). the defrost cycle would come on and melt the ice, but since the drain plug in the back of the freezer below the coils would eventually freeze up closed due to ice accumulation. It got to the point I had to shut down the whole unit and leave it open for around 8 hours to let it naturally melt the ice in the drain tube. I hear a gurgle sound and then a sound of water flowing, so I knew it was now draining again.
Posted on Jun 08, 2008
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
Does not fill with water
The water level detection is done via a small plastic pipe from the bottom of the machine that fills with water and causes the air pressure in the pipe to activate a micro switch in the water level detecter. The pipe can be disconnected at the bottom and gently blow into the pipe. If you listern carefully you can hear the micro switch click. The pipe must not be blocked and in some cases the switch contacts could be burnt. The water level is factory set but can be adjusted on the water sensor. Replace if necessary.
Apr 24, 2010 | Kenmore 24 in. 16049 Built-in Dishwasher
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Ice maker no longer making ice. A few weeks ago the water that was supposed to fill just the ice tray, didn't turn off, overflowed the ice tray and proceeded to fill the ice basket underneath. Since then...
Sounds like the water flowed enough to freeze the end of the fill tube shut. Best to prepare to replace the dual water control valve on the rear and near floor of refrigerator. If it was leaking and you should thaw the tube you need to turn the main supply of water off until replaced. Then thaw tube and replace the dual control valve. I will return with a part number providing your model number is correct, Thanks, Sea Breeze
Jan 17, 2010 | Maytag MBB1954G Bottom Freezer...
Ice maker won't fill with water
There is a soleniod near where the ice line hooks in, Take it off and clean it with hot water and soap, if that does not fix it it may be bad
Jul 31, 2009 | Frigidaire FRS26R4A Side by Side...
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Ice cubes melt together
check the fill cup on the rear of the icemaker to see if any ice is frozen in the fill cup if so remove the ice
May 06, 2008 | Refrigerators
Cimbali M 29
One thing to check... Have you switched to 100% reverse-osmosis or distilled water recently? I read that the water level probe needs conductive ions (e.g. calcium) in the water for it to detect that water has risen to the probe's level. So, water with too few ions will not register on the gauge, and the tank will continue to fill.
Apr 24, 2007 | Espresso RMI La Cimbali Espresso Machine
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
