Question about Canon SELPHY CP780 COMPACT PHOTO PRINTER(Pink)(3502B001) Battery
I have a Selphy CP780. It suddenly stopped feeding the paper and told me my cassette was out of paper. It wasn't. I used a brush to brush dust and blew it out with air. I still don't have a printer that works.
  • Kathy Moll Oct 24, 2010
    It is now working. Thanks.
  • Canon Master
  • 4,924 Answers
Check the paper not to be exceeding 19 sheets for normal and 13 for wide format ..than check again the paper cassette to be proper inserted..If it is still not working than try to reset it ..In the manual there is no special resetting procedure..so if it has a reset button use it ..or open the front door and in the maintenance menu look for reset ..
In case non present remove power cord. and press power/on button and keep it pressed while you connect it again ..This should reset it to factory settings ..
Posted on Oct 25, 2010
  • 10,865 Answers
Hi. Unplug it and leave it unplugged for two full minutes. If that reset procedure doesn't fix it, contact canon directly. J .
Posted on Oct 24, 2010
SOURCE:
Paper size incorrect selphy cp780
i have selphy cp910 coming option paper size incorrect why.pls can you any solation
Nov 05, 2013 | Canon SELPHY CP780 Thermal Photo Printer
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
Error paper feed in canon Selphy cp800
LOOK 4 A BLOWER OR BRUSH CLEAN THE SENSOR. LOOK FOR WATER AND CLEAN THE ROLLER
Mar 08, 2012 | Office Equipment & Supplies
I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
Dec 17, 2010 | Canon Office Equipment & Supplies
Cassette has paper in it; fresh ink cartridge; can hear the engine running, but I get a paper feed error Canon Selphy CP510
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Dec 21, 2009 | Canon Selphy CP510 Thermal Photo Printer
"paper-feed error"
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Jun 24, 2009 | Canon Selphy CP510 Thermal Photo Printer
I have a Canon Selphy CP510 printer. I have honestly not used it in a few months. I just got back from vacation and wanted to print my photos. I send the pictures from my computer to the printer. It...
If the rollers are working, but its not pulling the paper in, I would suggest, as suggested in another thread, to 'rough up' the rollers in an attempt to give them better grip and maybe a bit more circumference.
May 28, 2009 | Canon Selphy CP510 Thermal Photo Printer
Printer will not feed paper
Mine did that too.
I found that propping the paper feed cassette up at the end away from the printer worked.
May 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
Canon SELPHY CP780 COMPACT PHOTO PRINTER(Pink)(3502B001) Battery Logo
231 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
