Question about Samsung CLP 315 Laser Printer
Print start normally but half way through the print it jams. How do I fix this?
  • Samsung Master
  • 7,733 Answers
SOURCE:
Trying to print a 4x6 photo on HP photostock. First one printed fine. The second time it jammed. After fixing the jam, the pictures print up so high that the top half is cut off.
I have had a few HP printers that seem to get confused when something doesn't go according to plan. I eventually learned to switch everything off and walk away for half an hour.
Jan 02, 2017 | HP Office Equipment & Supplies
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
My printer HP Deskjet 1051 says there is a paper jam but no paper jam present
Use a flashlight to examine as much of the paper path as you can see. There may be a shred of paper left over from an earlier jam. There might be some foreign object such as a paper clip stuck inside.
Sep 14, 2012 | HP Deskjet 1051 All-in-One Printer
The deskjet 5650 has a flashing yellow downward arrow. What dies this mean?
Did you or one of your users have a paper jam recently and force the jam out of the printer? Because we've had a few 5650's do this after a jam. About 66% of the time this fixed it...Removing the ink, unplugging the printer, moving the print head to the half way point, and starting the printer.
Nov 28, 2010 | HP DeskJet 5650 InkJet Printer
My Samsung CLP 310 is having paper jam issue; it prints half and then gets jammed halfway; opening and closing the front panel sends the paper out but upper half of the paper prints ok but lower half shows...
You'll probably have to replace that exit sensor. Cleaning might not do it. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 02, 2010 | Office Equipment & Supplies
My paper starts to print but stops half way through and causes a jam???? what part do I need to get??
Might be the same problem that we see on the CLP 310s. Bad exit sensor. Go to YouTube and watch this video: 5fJHykzkfww
Jul 12, 2010 | Samsung CLP-510 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Can't remove program from computer because task stopped during print task
you might have a print job in the spooler, right click on your printer icon, select open and right click on any jobs, and select delete.
Apr 19, 2009 | Office Equipment & Supplies
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Samsung CLP 315 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
