Question about Toshiba 50H82 50" Rear Projection Television
Toshiba 50 rear projector tv
This morning i turn tv on and hear a pop noise and the tv colors all distorted all over screen. green red and blue like a wave picture across screen. sound is really good but unwatchable. What do you think?give me a hint how to fix. thank
I can't load the pic at this time broken dig cam, but the colors red and blue are diverge from each other especially at the bottom left corner. I hope this help out to narrow the problems. thanks
Posted on Jun 17, 2008
  • Toshiba Master
  • 8,617 Answers
Can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Posted on Jun 08, 2008
My 50 in Phillips rear projection has a bad green tint and switches to a bad red tint what can I do?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
Sony Projector Color Display
These sets have several common problems which are listed below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
The color seems to be off. No red, and lots of purple. This is a Toshiba 57H81 wide screen big box tv. It was purchased in 2002.
Could be a bad board within the tv but it is sometimes the source input meaning it could be dvd player, cable/satellite box, etc causing the loss of color but it is unlikely. I have one of these tvs and they use red green and blue projectors to reproduce the colors so when the red projector fails then you get purple which is green and blue colors combined without the red. I have found it to be sometimes a bad connection inside the tv and I found insects such as roaches inside others. Using extreme caution when opening the rear cover of any tv due to dangerous and fatal high voltage. You might find that simply cleaning out the inside of tv and reseating all the connectors might resolve your issue otherwise you would have haul this tv to a repair shop where you pay half the price of a new flat screen lcd for just repairing this tv which will probaly have another color go out next month.
Aug 15, 2009 | Toshiba 57H81 57" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
My Toshiba 50 inch projection screen TV isnt displaying
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Feb 14, 2009 | Toshiba TP50G60 50" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Convergence problem
my convergence are having a problem the blue color won't moved
Oct 03, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 65inch rear projection distorted video
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Aug 23, 2008 | Toshiba 65H84 65" Rear Projection HDTV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
204 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
