Question about Samsung UpStage SPH-m620 Cellular Phone
My phone won't turn on!
I turned it off and then when i tried to turn it on and then it won't.I tried 2 press the "reset" button but it still won't.But when i plug in the charger it will beep but nothing will show!
  • Alexsubia Jun 08, 2008
    Do you know where i can take it 2 be flashed??
    Guru:
  • 458 Answers
Your phone needs to be flashed. flashing is where new firmware is installed into your phone and it will become as good as new. take it to a repair center where they will do it for you.
it is risky to flash a phone on your own, you could end up destroying it.
Posted on Jun 08, 2008
  • Kenneth Obua
    Kenneth Obua Jun 12, 2008
    take it to a phone service center or to a phone repaire man,he will flash it for you
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
How do I turn on my ultratab C1059
The problem might be the battery. Please charge it full. If the battery is fully charged and still it won`t boot up, try this methods.
1. Remove battery, wait for a few seconds,
2. Reinsert battery.
3. Press and hold the VOLUME DOWNbutton,
4. Then press and hold the POWERbutton
5. Then release the POWER and VOLUME DOWN buttons
6. Press VOLUME DOWN to selectFACTORY RESET, and then press thePOWER button
Or this,
You can also use master reset. Hold down power button together with volume up or down button until you will see a screen in blue color with the logo>navigate and select wipe data/factory reset using your volume keys. Wait until your phone is completely rebooted.
Detached the SIM card to avoid contact deletion., likewise the SD card for file.
Jun 30, 2015 | Cars & Trucks
Incredible 2 phone won't turn on
your phone is not supported 32gb memory card that's why your phone is totally hang so if u want to fix it you have to update your software and go to a service station
Jul 09, 2017 | HTC Droid Incredible 2
Lock code factory reset issues
I'm not sure if I understand your question, but if you have lost your lock code, and want to hard reset, you could try:
Press and hold GREEN + RED + CAMERA when powering up, then
input default 12345 security code.
or maybe
  • To perform a hard reset on a Nokia phone that won't turn on, press simultaneously these 3 buttons:
  • on/off + * + 3
Remember that you will loose all data on phone.
Jun 19, 2012 | Nokia 5230 Cell Phone
I uploaded some songs on my htc. It gave some notification to send error report and I clicked no. I later took the phone to listen to the music I uploaded but it went off. I turned it on again and the...
Looks like the software got corrupted , you need to do a hard reset the phone .
1. Pull out the stylus.2. With the device turned on, press and hold the VOLUME DOWN andENTER buttons, then press the RESET button with the stylus tip.3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press theVOLUME UP button to perform the hard reset, or press any otherbutton to cancel the reset.
Nov 07, 2011 | HTC Touch Diamond Smartphone
My phone won't start, when you press the power button it tries starting then when it gets to the windows phone screen it restarts. Please help.
PLease do a hard reset ... Here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Press Vol down for reset .
Thumps up if this works ..:-)
Aug 09, 2011 | HTC HD7 Cell Phone
My droid screen suddenly turned black but i could still use it, i tried resetting it by pulling the battery out but the same thing occurs. Whenever i would turn the droid back on, the Motorola symbol is no...
You might want to try a hard reset on the phone, it should put your phone back to normal if its a software issue, if its a hardware issue you might have to take the phone apart or send it in for repairs or warranty return.
You can hard reset your Motorola Droid if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Aug 16, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Can't unlock phone I forgot my motoblur passcode and my lock code
You need to perform a hard reset on the phone. Follow these directions:
hese steps will wipe all data from the device.
1. Power off the phone. If the phone is frozen and won’t turn off using the Power button, pull the battery out.
2. With the device off, press and hold the Power andCamera buttons.
3. Release the Camera button when prompted to do so.
4. Press and hold the Volume Down button until a yellow exclamation mark appears on the screen.
5. Open the physical keyboard and press ALT + L, then press ALT + W to complete the hard reset of the Cliq.
That should do it! Good luck!!
Aug 10, 2010 | Motorola Mobility CLIQ Cell Phone
HOW DO YOU RESET IT
here"s how...i hope it will help you
1. Power off phone. If it won’t turn off, take the battery out.
2. Press and hold the Power and Camera button at the same time. Release the Camera button when prompted.
3. Press Volume Down key.
4. A yellow triangle will appear. Press on the screen just above the back key.
5. Select option wipedata/factory reset (Alt + W).
The Backflip will then complete the hard reset.
Jun 14, 2010 | Motorola Mobility Backflip Smartphone
I bought used touch diamond recently. But, the phone unable to to turn on Wi Fi after a few days even I tried to turn on through "Comm Manger" -> "Wi-Fi". Is the Wi-Fi device issue?
Try resetting your device to factory settings, but before doing so, please take a backup of everything (contacts, messages, calender etc.)To reset the device:
1. Turn off the phone and pull out the stylus.
"This operation will delete all your personal data, and reset all your settings...."
VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
It might take a while to start the phone and check the WiFi after the phone has restarted. In case it still has the same issue, then it might be a hardware fault.
May 09, 2010 | HTC Touch Diamond Smartphone
Samsung UpStage SPH-m620 Cellular Phone Logo
75 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
