Question about Samsung CLP 315 Laser Printer
Print starts normally but paper jams about half way through the print.How do I fix this.
  • Samsung Master
  • 7,733 Answers
SOURCE:
My printer HP Deskjet 1051 says there is a paper jam but no paper jam present
Use a flashlight to examine as much of the paper path as you can see. There may be a shred of paper left over from an earlier jam. There might be some foreign object such as a paper clip stuck inside.
Sep 14, 2012 | HP Deskjet 1051 All-in-One Printer
My Samsung CLP 310 is having paper jam issue; it prints half and then gets jammed halfway; opening and closing the front panel sends the paper out but upper half of the paper prints ok but lower half shows...
You'll probably have to replace that exit sensor. Cleaning might not do it. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 02, 2010 | Office Equipment & Supplies
My paper starts to print but stops half way through and causes a jam???? what part do I need to get??
Might be the same problem that we see on the CLP 310s. Bad exit sensor. Go to YouTube and watch this video: 5fJHykzkfww
Jul 12, 2010 | Samsung CLP-510 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
I get paper jam notice, remove jam and restart. There is no paper jam,when I try to print only half of picture prints
Make sure there is plenty of room behind the printer, the paper is drawn in the front and sticks all the way out of the back before it starts printing, it will show a jam if it can't get all the way out of the back slot.
Aug 28, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Samsung CLP 315 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
