How to connect all components to work
Hello I have 3 components that I need to connect to each so they all work. First I have a Sony Bravia KDL-32M3000 Serial 4551362 LCD Digital HDTV. I have it hooked up to my DCT6400 Phase lll High-Defination DVR Cable Terminal along with a set of cheap speakers that are hooked up from speaker to Cable box red & white audio plugs. Well now I have complicated everything by gettin a RCA RTD259 5 disk DVD surround sytem with 4 speakers for the side one speaker for middle of TV and a sub woofer. Along with many miles of different wires and plugs. I had them all hooked up from the DVD player to the TV with the DVD plugged into my cable box. Well I had reception but no sound. I don't know if these wires should go from the DVD to the Cable box or DVD to TV plugged into cable box or TV to the Cable box. The speaker wires must be plugged into the DVD with associated colored wires I know that but it's the other plugs and S-video cable and all the mess. I don't know what to do. I was so upset last night I unhooked it all and put my little speakers back on, but I hate giving up. Any ideas?
  • Patti Fearon Jun 08, 2008
    Yes I do have a manual for the theature system but it is more confusing than helpful. I did look at the manual for my TV and it shows a better diagram for connecting the 3 components so I will try that. It does show that I need a cable line with computer USB adapters to go HDMI which I don't have on hand but will get. Thanks
    Guru:
  • 1,894 Answers
You will have all them all in user manual itself right?
Posted on Jun 08, 2008
Our sony bravia has no blue color
If you are using the component video hookup which is 3 wire. green, Blue ,Red and red and white audio. be sure that all 3 of the video wires are pushed in all the way. check both ends. Replace cable. if all 3 are not connected then color will be be goofy. Let me know if this doe not help.
Aug 30, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
367 people viewed this question
 Grubhead
Grubhead
