Question about McCulloch Garden
How do i take apart an eager ****** mcculloch chaisaw to put on new gas lines
    Brigadier General:
  • 4,088 Answers
Drain the fuel tank, then remove a screw at the back end of the trigger handle, two screws at the rear of the case and possibly one or two under the rear case half. Keep track of which screws went where. The rear case should just pull off (watch the wire oil-pump lever which will come loose). The fuel tank pulls off rearward as well. This exposes the engine and main fuel line. Hope this helps!
Posted on Oct 24, 2010
6ya staff
SOURCE:
How can i install fuel line Eager ****** chainsaw
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 20, 2014 | McCulloch Garden
Mcculloch eager beaver chain saw
Hi Mike firstly check the air filter is clear and if so try putting some fresh gas where the spark plug goes into the block. If it fires its the gaskets on the carb. If it doesn't it's the gaskets on the block and it wont fire due to the compression being at fault.
Oct 20, 2013 | McCulloch Garden
Exploded parts view of mculloch 2014 eager beaver
Refer to your service manual.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 07, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Gas tank leaking
Nat, the gas is likely leaking from the carburetor, primer system or broken fuel line. I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Oct 16, 2012 | McCulloch Fuel Line Kit 155 165 100s Eager...
What is gas/0il mixture for mcculloch 2.1ci eager ****** model 60013203
Good quaility two stroke oil designed for chainsaws ( not out boards ) and designed to run at 50-1
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Looking for engine parts for an old mcculloch eager ****** weed eater. where can i find them? need to buy a new fuel tank and fuel lines
I assume you mean edger, not eager.
You must have the model number to find anything. You can go to the Mcculloch web site.
http://www.mcculloch.info/node1092.aspx
Here is an example of a parts list for one of their edgers maybe you're lucky and this is the one you need.
http://weborder.husqvarna.com/order_static/doc/MIPL/MIPL1994/MIPL1994_mtt2380g.pdf
Jul 25, 2010 | Garden
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
250 people viewed this question
Top McCulloch Garden Experts
roeb
John Trevino
Sheldon Dedek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
