Question about Ultratec Miniprint 425 TTY Printer
The Model # is 625.388460 and was installed May 2004. I don't hear clicking or a snapping noise. The motor is audible and sounds like it is turning the Cam and Gear. Every 15 seconds, you can hear the water run and then it stops, but the motor continues to run. On the display, "Serv" and "Recharge" blink simultaneously. Do you think it is still the motor? In the last 12 months, I've changed the switch twice and it fixed the problem. This time it didn't work. I also changed out the wiring harness and motor but still didn't fix the problem. If I need a rotor and seal kit, I see the part number for the rotor & disc is 7185500. What is the P/N(s) for the seal kit?
How do I replace the headlight leveler motor on a PT Cruiser?
LAMPS/LIGHTING - EXTERIOR PT
HEADLAMP LEVELING MOTOR - EXPORT
REMOVAL
(1) Remove headlamp unit
(2) Disconnect headlamp levelling motor electrical
connector.
(3) Rotate levelling motor one quarter turn counter clockwise.
This will free levelling motor housing from
the headlamp unit.
(4) Pull levelling motor straight from headlamp
unit. Significant force will be required to unsnap
motor control arm from lens reflector.
NOTE: The headlamp levelling motor control arm is
snapped into the lens reflector mechanism very
securely. Use a firm, steady pull to disengage motor
arm from reflector.
(5) Remove levelling motor from headlamp unit.
INSTALLATION
(1) While holding headlamp reflector assembly
still, push levelling motor until control arm is fully
seated into reflector mechanism. An audible "snap"
will be heard.
(2) Push and rotate levelling motor one quarter
turn clockwise to lock motor to the headlamp unit.
(3) Connect headlamp levelling motor electrical
connector.
(4) Install headlamp unit in the vehicle Locksmith Buffalo Ny 24 Hour Locksmith in Buffalo Ny 716 249 2944
May 17, 2016 | 2004 Chrysler PT Cruiser
Any ideas ?
There is a problem with the starter solenoid or the starter teeth aren't syncing properly with the engine. With such low mileage, I can only assume the starter has been used when the engine was running.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Jul 19, 2014 | 2004 Yamaha V Star Classic
2004 chrysler pacific will start sometimes but sometimes won't
I would suspect the fuel pump is the problem, it may be sticking at times and this causes a no start. The pump is located inside the fuel tank and it is electric.
Mar 28, 2017 | 2004 Chrysler Pacifica
I have a 2004 Dodge Grand caravan that won't start. (60,000 miles) I hear a clicking noise and my gauges go "crazy" when I turn the key. (Speedometer goes from 0-120 and back to zero when I turn...
Sounds like a classic case of a dead battery. It takes much less energy to sweep the gauges and turn on the lights than it does to crank the engine over. The clicking noise is usually your starter solenoid trying to engage and spin the starter. Try a new battery. Happy motoring.
Good luck.
Jan 18, 2011 | 2004 Dodge Grand Caravan
In my 2004 Trailblazer a clicking noise starts about 1 minute after the car has been started and then the clicking continues for about 90 seconds. The clicking is audible from the inside and outside but is...
I should guess it to be the electric fuel pump, although I thought those sounds had been eliminated by the manufacturers long ago. Perhaps you could raise the car in the air and get underneath it and see ( or I should say "hear")
That sound from the fuel pump should not mean it is bad or is going bad.
God bless your efforts.
Oct 17, 2017 | 2004 Chevrolet TrailBlazer
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera lens
Apr 29, 2007 | Canon PowerShot A510 Digital Camera
Canon Ixus 40
Apr 27, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Ultratec Miniprint 425 TTY Printer Logo
59 people viewed this question
Top Ultratec Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you an Ultratec Office Equipment and Supply Expert? Answer questions, earn points and help others
