Question about Caterpillar Backhoe Tractor
Cat 416c model 1wr. won't always go into forward however reverse always works. tx fluid level and condition good. once it starts working it seems normal. suspect problem is wiring....need wiring diagram if anyone out there has one.
2 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: Cat backhoe doesnt even go up a hill in forward, reverse is fine
http://www.heavyequipmentforums.com/showthread.php?t=19510
If you go to this site, and join, AFTER you make five posts, ie: comments on any topic anywhere on the site - five times (hit reply button on any post and comment) you can ask any questions concerning any equipment known to man or beast. It's free and a very good site with tons of great info and pictures.
Posted on Aug 29, 2010
1989 Chevy cavalier Z24 transmission
Change fluid and filter.add a bottle of lucas transmission oil also.
Aug 20, 2017 | Cars & Trucks
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
96 ROVER DISC. Has strong reverse - won't engage any forward gears. Fluid seems full even when warm.
Make sure the 4wd shifter is in correct position and hasn't slipped out of correct spot to get you moving forward.
Mar 27, 2013 | 1995 Land Rover Discovery
When reverse is selected idle speed increases very little but no movement
Soun like a problem with the Torque Converter or valve solanoids stucked. FIrst checl trans fluid level in good conditions (without brun smell odor and clear colors).
Jul 20, 2012 | Cars & Trucks
Hello, my 01 mazda 626 has no forward at all. the reverse works barely.. an expert told me to peplace the tranny so i did and still has no forward.. The reverse still works. the torque converter bolts are...
did u remove the transmission and have it fixed or u just got one from the junker because shoul have low gear forward at least if ur second tranny have a good reverse and no low frward seems u pick a bad one and assuming the fluid level is good
Nov 21, 2017 | 2001 Mazda 626
I have a 1998 Oldsmobile Bravada auto trans drive works fine but no reverse
Are you sure you have all 4 forward gears? Most of the time a no reverse condition also means 1st and 3rd only.No 2nd or 4th.If you dont have all the forward gears as i suspect , the reaction shell is stripped or broken.If you do have all the forward gears then these are the two most common reasons you do not have reverse.1 reverse input clutches are damaged or burnt 2 forward cltches have slipped to the point they are welded together causing a mechanical bind in reverse and also causing the transmission to pull forward in neutral.Let me know if i can help.Good Luck.
Feb 28, 2011 | 1999 Oldsmobile Bravada
I put my '98 Ford Ranger into reverse and it did nothing. All the other gears worked except for reverse. It seems that I now have two neutral gears. Is there something that I can check before taking it...
Hi!
After vehicle has been driven a couple o miles, check transmission fluid level and condition (in park, motor running) should be of a pinkish color, almost transparent if looks darker, change fluid and filter. If level is low, check for leaks. Replace with manufacturer recomended type.
If your problem just started, there is a good chance to fix it following my recomendation.
Good Luck!!!
Mar 20, 2010 | 1998 Ford Ranger SuperCab
2OO2 TROOPER HAS NO FORWARD GEARS, BUT HAS REVERSE.
First check you fluid level,if good have it flushed out with new fluid,if this does now work,time for rebuild,unless you know how to adjust the bands.
Jun 22, 2009 | 1999 Isuzu Rodeo
Transmission wont engage or disengages
I would inspect fluid level and condition. Smell the flud on the dipstick. Smells burnt, might be too late. Hope this helps.
Apr 08, 2009 | 1994 Oldsmobile 88
Caterpillar Backhoe Tractor Logo
314 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Marvin
Marvin
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
