Our soyo mt-sytpt3227ab tv won't turn on, light keeps flashing red off and on
4 Suggested Answers
SOURCE:
SOURCE: When I plug in my SOYO MT-SYTPT3227AB LCD TV it
If you want to know how I did it send me $9.95
Posted on Jun 29, 2009
  • 910 Answers
SOURCE: I have SOYO MT-+SYTPT3227AB TV
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
Posted on Jun 10, 2011
  • 121 Answers
SOURCE: what is the remote learning code for my 32" TV
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Posted on Sep 25, 2011
My Soyo tv Mode MT-SYTPT3227AB displays black and white and no Sound how can I fix it.
If your country uses the PAL TV system make sure the TV tuner is not set to NTSC.
Aug 07, 2016 | Soyo Televison & Video
Soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
What is the optimal picture setting for a model # MT-SYTPT3227AB, please give the numbers.
If you're using it as a computer monitor, go with the native resolution of 1366 x 768. If you're using it to watch TV, you could choose 720P or 1080i. You probably couldn't tell a difference between the two, but if you watch sports (or fast moving objects), go with 720P.
Jul 27, 2011 | Soyo SYTPT3227AB 32 in. LCD TV
I have SOYO MT-+SYTPT3227AB TV and cannot locate mounting holes to wall mount the TV.
Jun 10, 2011 | Soyo Televison & Video
Soyo MT-SYTPT3227AB where is the tcon board located?
The t-con board is located at the top-middle of the set. I have enclosed a picture of what they look like.
Nov 27, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Soyo 32" lcd tv
The only part I could find was at shopjimmy.com, part being a Polaroid PCB for $69 plus tax, ship & handle.
Feb 24, 2010 | Soyo SYTPT3227AB 32 in. LCD TV
My soyo mtsytpt3227abms tuns on says soyo and then turns off
Complete loss of power points to the main power supply, a weak point in the majority of set failures.
Leave the set unplugged overnight to allow any residual charge to bleed from the power supply. Open the back panel of the set and look for a separate board that appears related to the incoming AC and has larger components on it; cylindrical cased capacitors and blocks that are transformers and chokes. If you find this, it will likely be something you can remove and replace yourself. Take a picture before removing cables or the board, although different connectors normally preclude incorrect assembly. Look for a part number on that board and contact the manufacturer to inquire about repair or replacement costs. Even if repair is offered, it may not be much cheaper than a new board. If you go with a new board, don't toss the old one, there are smaller companies specialized in the repair of these and you will probably need a spare.
Jul 24, 2009 | Microsoft MT-SYTPT3227AB 32 in. LCD TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Ekse
