Question about Garmin nuvi 205W GPS Receiver
D my garmin nuvi 650 does not respond I turn it on & get stuck I toch the screen but does not respond
    New Friend:
  • 17 Answers
You need to do a factory reset, look for a tiny hole and you can push a toohtpick in to reset....
Posted on Oct 24, 2010
SOURCE:
My garmin nuci 650 isnt responding to the touch
Turn your unit off then back on...... Slide Power key to the right ( Lock ) Hold your finger on the screen for about 30 seconds until the calibration screen appears Follow on-screen instructions
Oct 26, 2010 | Garmin nuvi 205W GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen not responding at all. Garmin powers up okay.
This is Garmin's response to me after having the same problem on a 2 year old Nuvi 650: We are no longer replacing or repairing this model unit. However, let me give you some steps to try to calibrate the screen of your unit. The following 'Fix' did not work. I won't be buying another Garmin.
To recalibrate the touchscreen on your nuvi 600 series device please follow the steps below:
  1. Plug the device into the computer via USB data cable
  2. Double click My Computer (Mac Users can skip this step)
  3. Double Click the Garmin or nuvi drive
  4. Double click the Garmin folder
  5. Delete the GUPDATE.GCD file (if this file is not on the device please skip to the next step)
  6. Unplug the GPS device from the computer
  7. Power the device off
  8. Press and hold the Power button
  9. After a short period a screen should appear that says Touch Dot
  10. Release the Power button
  11. Touch the dots as they move around the screen.
Your touchscreen should now be recalibrated.
If the screen is still not responding, then the unit will need to be replaced with a new unit at this time.
With Best Regards,
Benjamin B
Product Support Specialist
Automotive Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Benjamin B, Associate #6891
www.garmin.com
Additional solutions may be found at http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Sep 05, 2010 | Garmin nuvi 650 GPS Receiver
Nuvi 650 touch screen stopped working
My Garmin Nuvi 650 would boot up and load maps, but I could not enter my access code. Screen would not respond. Turned off & on a number of times, but still same problem. This occurred on first use after upgrading the maps. Thinking it may have overheated on the dashboard of my truck, I held the device in front of the air conditioner vent for about five minutes to cool it down. When I then turned it on, it worked fine. For the rest of my 3-week vacation, I kept it cool & out of the sun when it was not turned on. No problems after that.
Jul 17, 2010 | Garmin StreetPilot c340 GPS Receiver
Touch screen not functioning
Please see this link. Most likely uou have one of the newer SHARP touchscreens that is known to fail prematurely.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Dec 15, 2009 | Garmin nuvi 650 GPS Receiver
Not touch sensative
In 90% of the cases it's the digitizer (the touch sensor that is mounted in front of the screen). You can try to replace it yourself or send it to a third party gps repair service.
Jul 24, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 650 powers off when connected with car
I had this problem. The problem turned out to be my car charger. Hooking the GPS up to my computer allowed it to charge and operate normally. A new car adapter might fix you right up.
Jul 06, 2009 | Garmin nuvi 650 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
151 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
