Question about Vizio Televison & Video
I plugged it in and it started to smoke, now it's not coming back on can a fuse be replaced?
  • 11,361 Answers
I will be more than just the fuse that needs to be replaced, you need to find out where the smoke is coming from and replace that parts or module, you do want to take a chance buring down you house next time it happens.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 24, 2010
SOURCE:
What would cause alternator to read regulators out when its not out
Best to get it to a workshop if smoke is coming from fusebox you definitely have some damage.
Jan 21, 2016 | Cars & Trucks
Smokes and smells like gas at muffler
That has to be gas that is not being burned! No idea why blowing a fuse with the air compressor rashed your car like that - must be coincidental or collateral damage.
Sep 04, 2017 | 1994 Ford Mustang
I have a vizio vp50 hdtv20a. A while back we turned it on no picture and it started to smoke. After reading a little about it I decided to take off back panel and see if I could locate burnt part. Could...
That board directly connects to the display panel---you may have a bad display panel which if is the case is fatal---panel alone will cost more than the set did when new----seen this before in the shop where I repair sets.
May 03, 2012 | Samsung Televison & Video
Ws having to leave volume at high level for sound now smoke and blowing fuses
All you need to do is replace the part that is smoking and the fuses and the unit might come back to life. As the burning part is most likly the cause of the fuse blowing.
Jun 20, 2010 | JBL PSW-D110 Speaker
Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
2001 Jetta Tdi runs rough
Hi Whitneyford
Your priblem sounds more like the glow plug timer relay than the exhaust. White smoke after start up is a sign of diesel entering the exhaust before it has burned completly. This is as a result of the glow plugs switching off too early, which is usually caused by one or more faulty glow plugs or a faulty timer.With engine COLD, IGNITION ON... Check voltage with all 4 plugs connected. You should have a reading of 10--12 volts
If there is no power, check in-line fuse on loom coming to plugs.
If power is present, check for How Long. If only for a few seconds, the problem is with the timer. This unit (the larger of the relays and usually black in colour) is fitted on the fuse board, and there are a few different types. They come in 7 pin..8 pin..and even 9 pin units.
The glow plug light is often NOT accurate (even with a new timer unit fitted) as to the time of heating, and you will almost certainly find that power will flow to the plugs for quiet some time after the light goes out. This is not unusuall with The Jetta Tdi.
Good luck.
I hope this helps you sort out this problem
John
Aug 18, 2009 | 2001 Volkswagen Jetta TDI
Rear defroster fuse keeps blowing
Get you some rin foil and put on the fuse and plug it back in. Where ever the short is. It will start smoking. So becareful and keep yours eyes open for smoke or burning. You will darn sure find the problem.
Good Luck.
Feb 02, 2009 | 1997 Mercury Grand Marquis
Vacuum plugged in but not on, smoke started coming from the motor
The motor winding burned out. Perhaps the motor was very hot when the vac was turned off after the last use and the insulation of the motor windings broke down when the air stopped moving thought the unit. Perhaps also the polarity of the receptacle it was plugged into is reversed or the plug on the vacuum is not polarized. Those things in combination could cause this but this is kind of a long shot guess. In any case the blower motor is likely burned out and will need to be replaced and checked out.
Jan 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Smoke
started and then started smoking a lot please help.?are you saying it started smoking from the exhaust? or that you saw smoke coming from the electrical?? it sounds to me like you have a major short and it is burning up wiring etc. Don't run it if this is they case, get it to a bike shop for repair,,,
Nov 10, 2008 | 2001 MZ 125 SM
Televison & Video Logo
188 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
