Question about LG Audio Players & Recorders
I have a LG DVX 480 DVD Player and want to know how to unlock it to be able to play all regions. Help me. Thank you
  • alaupre Oct 25, 2010
    My DVD player is set in french language must I set it in English?
    My player is not a LG DV 480 but LG DVX 480.
    I tried that :
    1) I power on
    2) I wait for nodisc
    2) I open the DVD door
    3) I press pause
    4) I press 3,1,4,1,5, 9 but there is not a screen prompting for region code, the screen on TV doesn't change (allways "no disk")
    what can I do?
    Thanks very much for your help.
    I tried pause+enter or stop after open the door but that doesnt work. I tried the JorgolLGDVX276hack.iso but that doesnt work.
  • LG Master
  • 4,924 Answers
Http://www.dvd.reviewer.co.uk/info/multiregion/full/aiwa370.asp
Posted on Oct 25, 2010
  • 8,197 Answers
The hack of converting the LG DVX480 works very well. The DVD door MUST be open before proceedeing. I found it best to wait 1 minute before re-starting but after that is works fine. So, once you have started the LG DV480 you,
Press pause on the remote
Key in 3,1,4,1,5,9
In response to the screen prompting for region code, choose 0
Press Pause
Power Down
Wait 30 secs or so
Power up and we were away.
Posted on Oct 24, 2010
SOURCE:
How do i unlock my LG BH7520 blue ray dvd player to play multi region or region 2 thank you
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your player(region free). However, some DVDs (multi region in particular) will not play, since they require region detection from the player unit.
Sep 23, 2013 | LG Televison & Video
DVD PLAYER MULTI REGION CODES
you can change your dvd region code but i advise you not to change it instead use a software . here is the link for the software to download :- http://www.4shared.com/file/19492658/43612f11/DVD_Ghost.html?s=1
if it doesn't work then contact me ok.
Jun 28, 2008 | Televison & Video
Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Mar 25, 2009 | Sylvania DVC-840E DVD Player/VCR
Region unlock for LG DV480
If you have the LG DV 480 then try these steps
1 Turn the DVD player and open the disc draw, leave it empty
2 Press Pause
3 Type 0000
4 When the blue screen appears type "0" in the new region code
5 Press Pause
6 Power off the DVD player then turn it back on
It worked for me
Mar 15, 2009 | Televison & Video
Code to unlock LG DV390H DVD player
I have an LG DV390H also and the answer provided by jaffa012001 works!
So do this guys:
-switch dvd on
-open tray
-on your remote control press 000 (number zero three times)
-the region menu appears on screen
-go to where it says region and press 0 (zero once) then pause
-switch off
it works! thank you jaffa012001..youre a champ!
Mar 12, 2009 | Televison & Video
LG DVX 380 Region Code Unlock
This fix for a LG DVX 350 worked on a region 2 (Europe) LG DVX 380 player:
http://www.videohelp.com/dvdhacks/lg-dvx350/9792
You need to burn the ISO image to a CD then put the CD into the DVD player. A region menu appears, select 0.
Jul 24, 2008 | Televison & Video
Regional code
open tray
Press PAUSE
enter 0000
The region code set page should appear.
Set code. 0 for multi region
Press PAUSE.
OR
Make sure your TV is on and the DVD player is active on it
Unplug the DVD player
plug it back in
wait for text "nodisc" to appear on the DVD display
Use remote control to open tray (tray must stay open)
Use remote control to Press "Pause" (you won't see anything)
On the Remote control number pad enter the number "0000" (4 zeros)
The region code setup window will appear on your TV
on the remote control number pad enter number "0" (zero)to set multi region
Use remote control to Press "Pause" again
close tray
Jun 06, 2008 | LGDVB418 DVD Player
Region code unlock
hi
you can try this here LG DV8621P
let me know if works .
riz.
May 17, 2008 | Televison & Video
Unlock LG DVD to play all regions
hi, I suggest unlocking using the remote handset. I unlocked my LG dvd player using this method, you can find the instructions depending on your dvd player model. I didnt find the exact model but i tried with a very similar one and it worked. I dont know if it will work for you, but you can try, hope it does. http://www.dvdcodes.net
May 15, 2008 | Televison & Video
Multi region dvd unlocker
This can only be done on some dvd players unfortunatly. They are locked to regions because of the video format types that vary from country to country.
Mar 07, 2008 | Yamada DVD-5520 DVD Player
476 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
patseamur
Level 1 Expert
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
