Question about Microsoft Xbox 360 Console
Xbox disc tray wont open - Microsoft Xbox 360 Console
  • 767 Answers
Press the eject button wait one second and FIRMLY
smack the top of the console just above the drive and it
will open.
The cause is either a weak eject motor or to much grime
and build up in the Gears preventing the motor from breaking
the magnetic seal between the hub and spindle.
I normally just gap the hold down magnet in the drive
so the motor can break the mag seal with less force
and that seems to work well.
Rob
Posted on Oct 24, 2010
  • alnrs Dec 27, 2010
    I had the same issue so now I keep a disc in at all times and it works fine.
SOURCE:
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Loose disc tray
well, when you opened the tray with a paperclip, it probably jacked up the reading system. The you pushed it in manually. This will totally ruin the system. Try contacting Microsoft.
Jan 16, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Tray wont open
Power your unit off using the button. when it's off unplug the power source from the back of the XBOX and leave it out for 30 sec. Reconnect the power source and reboot your machine. Try the disc tray again. If it doesn't work try giving it a tap or a solid knock on the top of the case above the disc tray while it's trying to open. Don't drop the machine or try to pry the tray open. If it doesn't open when you tap it then try light pressure on the front of the tray while it's trying to open. (you can tell it's trying to open because the disc status on the screen will say opening...)
Now if the above did not work
Get a straightened paper clip.
Remove the faceplate carefully starting from the indention that you will see on the side
After removing the faceplate, look for a pinhole just below the disc tray.
*There are two pinholes just below the cover of the disc tray and one pinhole below the X and B of XBOX logo.
*You can try any of the three holes
*Pinholes are so small that the girth of the paper clip is the only object that can fit through the pinhole.
Now insert the paper clip into the pinhole then put a little pressure until the disc opens.
If it opens try to close it, if it closes try opening it again, if it wont open the second time then it need to be serviced
If it opens try to close it, if it wont close try nudging the disc to the right and then to the left, if nudging doesnt then it need service
If it wont open after trying all three pinholes - its needs service
It may be jammed or the drive gear stripped.
CALL XBOX CUSTOMER SUPPORT 1-800-FORMYXBOX
If that doesn't work . call Microsoft and they will instruct you on warranty work.
Nov 24, 2009 | Microsoft Xbox 360 Console
Disc reading problem
use a disc based lens cleaner. opening your xbox console will void your warranty.
Aug 20, 2009 | Microsoft Xbox 360 Console
My xbox will not read any of my games
try playing a different game *******
Jul 29, 2009 | Microsoft Xbox 360 Console
Xbox wont read discs, unless i hit it....
open tray right??
-check the time and date settings,even the time zone as well
-try to load the disc without the hard drive or memory unit
-look for corrupted files at the memory, delete it
-do the system maintainance,
system settings>>memory>>hardrive, press y for device options, press this in sequence x, x, Lb, Rb, x,x>>yes
Jun 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont recognize game discs
your lazer has packed in my sugestion is to buy a new one. i had the same problem
Jun 24, 2009 | Microsoft Xbox 360 Console
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
May 12, 2009 | Microsoft Xbox 360 Elite Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
214 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
