Question about D-Link AirPlus Xtreme G DI-624S Wireless Router
WTF! internet used to work perfectly and now my wireless router is on the fritz and the status light keeps flashing! i have to hook my comp up to the wall to write this message
    Sergeant:
  • 185 Answers
If the status led light keeps flashing there is a problem on your ISP side. Router is trying to establish connection with internet. Please check led light status on your modem (not router). Also please try to change position of your router as it might be in a "dead spot". For more info about your router please visit: http://www.dlink.com/products/?pid=6
Posted on Oct 24, 2010
6ya staff
SOURCE:
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
My dsl light is flashing and the 2wire router just clicks over and over again. All other lights are on and green except for the Internet light (because dsl is flashing). Router has been working perfectly...
or LED LIGHTS interpretation: refer to this link:http://www.sasktel.com/search/controller//Internet/2Wire-Gateway-2700-2701-LED-Status-Lights-Guide/_/R-Support_13750/Record-Support
NOTE: everything that says contact SASKTEL TECH SUPPORT refers to your Internet Service Provider
Qwest Technical Support at 1-800-247-7285
SASKTEL TECH SUPPORT Anywhere in Saskatchewan :1-800-773-2121
Outside Saskatchewan (anywhere in Canada and USA):1-888-773-2122
Anywhere else in the world:1-306-522-1820
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Hope This helps
Jun 25, 2011 | 2wire (2701HG-B) Wireless Router
My router went to all lights on and i resetted it and now only the power and status lights are on but i try to put the internet cable into it and it says it works and the wan is flashing but the staus...
Go to:
Start/Control Panel/Network Connections and right click on Wireless Connections then left click on Repair
This works sometime. Also you might want to restart your modem as well as your computer to get everything in sync.
Aug 27, 2010 | D-Link AirPlus DI-524 Wireless Router
Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
How to configure the router for Time Warner?
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
3.Under Internet Settings, change the connection type as Dynamic.
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
For any advanced help, revert asap!
Thanks and regards,
Arvind
Jul 04, 2010 | Belkin F5D8236-4 Router
Belkin N router reads everything but the computer.
If your router was working before, and suddenly stopped working, then you probably need to reset it.
Unplug the router from power, also unplug all network cables from it.
Wait about 30 seconds.
Plug power back in, followed by network cables.
Wait some more seconds while the router restarts.
Only the Power light and the Status light should be solid.
All others in use must be blinking, which means they are in use.
Try connecting to the internet with cable first, then try wireless.
It should work.
Please don't forget to rate if answer is helpful
Jun 22, 2009 | Acer Aspire 5050-3242 Notebook
Airnet router with blinking status light
first, check and make sure you have the correct power adapter for the router. second, reset the router my holding the reset button for 30 seconds
May 09, 2009 | Computers & Internet
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
Wireless router problem
Look I have found virtually 98% of the time these problems disappear after a "New" unit is substituted... so my punt is for ya Router...
Sep 10, 2007 | Computers & Internet
Open Questions:
TEXAS 1-************ Crypto phone Number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
Oct 22, 2019 | HIS Computers & Internet
See all D-Link AirPlus Xtreme G DI-624S Wireless Router Questions
D-Link AirPlus Xtreme G DI-624S Wireless Router Logo
204 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
