Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
TV color My TV is showing mostly in green.
  • 84 Answers
Unplug power to all equipment and plug in again to reset usually helps
Posted on Jun 22, 2008
After turning the tv on the colors are reddish and slow to conform to the normal color tones. i have a 36" toshiba flat screen tv
My first concern would be that, the picture tube is going bad. The problem you describe, tell me one of the color guns is shorting. In this case I would think the green gun is shorting. There are three color guns in the neck of the picture tube. They are red, green, and blue. Most of the time the green will short as it is powered heavily in most TVs. The next thing to check, is the small board connected to the picture tube. Look for any and all bad grounds on this CRT board. This is another big problem in all Tube type TVs. On this small board there will be three color output transistors, and resistors. These will many times run very hot and will create bad grounds over time. Check and resolder as necessary. If the CRT board does not fix your problem, replace the TV. Picture tubes are very expensive and will not be feasible for replacement. Search for a new TV. Thanks for asking and show all hands of support!
Jun 26, 2011 | Toshiba 36A43 36" TV
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Green hazy upside down arch of color across the screen
Your convergence board is in need of reworking on a component level or replacing the board! And you will most undoubtedly need to resolder the vertical IC and all ICs mounted on heatsinks on the power supply board. This TV is showing its age. You may choose to repair and that may last a year more or so! Good Luck and thank you for asking!
Jun 20, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Mar 02, 2010 | Emerson LC320EM8 32 in. LCD TV
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Blue color's showing green....PLEASE HELP!
Try to do some adjustment in the Service Mode (had better ask tv technicians to do it). If not work, you need to replace the Small Signal Board of your tv.
Dec 30, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv has a brownish green tint to it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Dec 03, 2007 | JVC AV-56WP30 56" Rear Projection...
THE GREEN SCREEN
using a dmm check the resistors on the kine board. the small board on the back of the picture tube. you sould find an open resistor. if i remember correctly, if looking at the back it would be on the bottom of the board & about 180k ohm. if you have a difficult time finding it, look for the same type/color of parts on the small board to make comparrisons. between parts. you sould have 3 of most parts, one for each color. good luck.
Nov 20, 2006 | Emerson TS1997 19" TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
