Question about Logitech G25 Wheel And Pedals Set
I have a problem with my logitech g25. Earlier i used xp 32 bits system, but when I upgraded to vista 64 bit recently i got some problems with it. When i just touch the throttle or the brake pedal, it gos to 100% throttle or brake power. its no modulation. Help?
SOURCE:
SOURCE: logitech lx7 mouse
Go to logitech.com, then download and install Setpoint.
Click Start, then Logitech, then Connect Utility.
Follow the instructions as they appear onscreen.
Posted on Sep 09, 2008
  • 54 Answers
SOURCE: Logitech S-220 Speakers
Hi cfbruce,
First, double check your startup/user's guide cd and retrace your steps just to rule out the small stuff, you know, jacks are in tight, if its a 5.1 surround system the center speaker may have an on/off volume knob. Your speakers may have a player utility that needs to be configured i.e your utility may be set to headphones. Select the configuration that most resembles your speaker setup i.e headphones, cpu 2 speaker, surround, 5.1 or 7.1 etc.. and last, but not least, make sure your system is not muted. This will drive you crazy if you don't know the system is muted.
I hope this helped a little, if not , hit me back, we have other options.
Thanks for using FixYa.com
Sincerly, cyyyd7
Posted on Oct 09, 2008
  • 8 Answers
SOURCE: Logitech G25 steering wheel Resets from time to time
These wheels I have no experience with, but my gues is if it uses batteries or plugs in, the batteries are dead or the plug is losing connection.
Posted on Feb 18, 2009
SOURCE: Wingman extreme digital 3D Logitech not working on XP
Well you can try download lgs501.exe and run it. This scans on Logitech drivers on your system and can even update them.
( Not checked though, cause I am running on Vista )
  • 118 Answers
SOURCE: logitech g25 steering axis not working wheel returns to center
to chk the sensor on the calibration unplug the wheel from the usb port and plug back in if the wheel turns left then right and centers the sensor is fine. go to the control panel>game controller>properties and test the wheel if everything is working there it is a problem with the game. look for a profiler or calibration utility in the game itself to bring back to center.
Posted on Jul 18, 2009
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
Lexmark x4550 driver
You can download the drivers from the following links. If you did mention the Operating System's name, it would be easier for both of us.
1. Mac OS X 10.5 and earlier version
2. Mac OS X 10.6
3. Windows XP and Vista 32 bit
4. Windows XP and Vista 64 bit
5. Windows 7 32 bit
6. Windows 7 64 bit
If you need further help, let me know with more specific details.
Good luck.
Oct 05, 2010 | Office Equipment & Supplies
Vista x32 want to upgrade vista x64
microsoft provides upgrade discs from it's site (you should payteh freight).
If u are using Microsoft Windows Vista Home Basic, there is no way to upgrading.
else, the other versions allows u to upgrade.
remember: the only difference between 32 and 64 bit is the RAM memory usage (32 bit will not use more than 3,2GB RAM), and there are a lot of programs that won't run properly in 64 bit version .
Jul 26, 2009 | Microsoft Windows Vista Home Basic with...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Software incompatibility on my acer aspire6930-6455
Well, we wont know until you try. In my opinion, your 32/64 bit issues will be solved, but you would still have the normal vista/xp compatibility issues.
But that is to be expected, like when we all upgraded from win98 to XP.
So - I would recommend downgrading to Vista 32 bit, or getting the 64bit software version of the programs you want to use.
Good Luck, and let me know what you did, and how it turned out! :)
Jan 07, 2009 | Acer Aspire AS6930-6455 16" Notebook PC
Upgrade vista home premium
As per my knowledge, there is no version of Vista called Vista Professional like in Windows XP.
Make sure what is the version to which you want to upgrade to from Vista Home Premium to Vista Business or Vista Ultimate.
The available versions of Vista Operating Systems along with the features supported from the Link below :
http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
However, if you want to Upgrade the current version of Vista to a higher version like Vista Business or Vista Ultimate, you need to purchase Vista Anytime Upgrade kit from any retail store or directly from Microsoft.
You can find the required information related to Anytime Upgrade Kit from the link below :
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
However, make sure that you had created the Recovery Disks for your notebook using which you will be able to reinstall the preinstalled Operating Sytem along with all the Preinstalled Applications and Drivers after which you need to use the Vista Upgrade Kit to upgrade to higher version of Vista.
However, if you are currently having a 32 Bit Vista preinstalled in the Notebook, it is not possible to upgrade to a 64 Bit Vista since you can upgrade only a 32 Bit of Operating System to a higher version of 32 Bit Operating System and a 64 Bit Operating System to a higher version of 64 Bit Operating System.
Hope this helps....
Nov 12, 2008 | HP Pavilion dv6000z Notebook
Question?
You will most likely need to select the "Multilingual 32-bit" option. If you're using the 64-bit version of Windows XP or Windows Vista, then select "Multilingual 64-bit"; the "normal" versions (that almost everyone uses) of XP & Vista are 32-bit.
To explain this a little further, here's how to tell if your PC is even capable of using a 64-bit operating system. Right click on "My Computer" and select "Properties", then select the "Advanced" tab. Near the bottom, select "Environment Variables". Scroll down the "System variables" until you find "PROCESSOR_ARCHITECTURE" (under the "Variable" column). If the value shows "x86", your pc has a 32-bit processor; if the value shows "x64", your PC has a 64-bit processor. Cancel out of this.
Using the software from the web site is much more current, anyway; the software on the CD that came with my camera was very outdated.
Hope this helps.
Ray
May 29, 2008 | Logitech Quickcam IM 961361-0403 Webcam
Logitech G25 Wheel And Pedals Set Logo
132 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Ekse
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
