Question about Runco CL-510LT Multimedia Projector
My 6 year old projector which sees use maybe once or twice a month will not turn on?! Batteries were changed in the remote and all connections and power source issue are good! Just no turning on! No other manipulations or changes to the device have been done. Do I have to call my "very expensive" AV/installation service guys out to check it? Chip Becker
Battery won't stay charged and has been repalced twice since October
hi, you replaced the batteries twice? using the same charger, have you tried another charger ?, okay let me tell you about mobility scooter chargers, it quite complex but some chargers will charge your new batteries correctly due to resistance etc, it more complex than this however now as your batteries get older your charger maybe having a problem charging your batteries , not because they faulty, now this is due to internal resistance once again the batteries problem reappears within 3 to 6 six months , it could be just the batteries are not good enough , I have seen a whole combination of faults , please bear in mind there are some dodgy batteries out on the market....
so
1. first try another charger
Regards
Jan 19, 2013 | Pride Mobility Go-Go Ultra X 4 Wheel...
No lights are lit on my Nexus Remote monitor for my Generac standby generator. The generator is working - just went through the testing cycle. Batteries are less than 6 months old. Maybe I need to...
batteries only last about 3 months on these units. make sure you are within 20 ft of the generator and put in new batteries. The green light will blink is a minute or so.
Apr 23, 2011 | Generac Power Systems Generac 5928 Nexus...
I cannot get my remote to work with my Sanyo PLC-XE30 projector
I would first try changing the batteries in the remote and verifying that batteries are in the right direction (+ and - terminals line up).
Once that is done, try pointing the remote right at the infrared sensor at the front of the projector...the black plastic circle on the front of the projector.
Mar 04, 2011 | Sanyo PLC XU30 Multimedia Projector
My projector want turn off. New batteries in remote.
you have to press the red button twice !! on screen you should see POWER OFF ? after first press, press once again to confirm.
Check if key and remote lock are both off.
Dec 19, 2010 | Eiki LC-XG110 Multimedia Projector
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Mar 13, 2008 | InFocus ScreenPlay 4805 Multimedia...
LCD projector no signal message
Usually means that the computer is not sending a signal out the the projector via the monitor cable. Most Windows based laptop computers allow you to connect to a second monitor by pressing the Fn + F7 or F8 key, once to allow just the projector, twice to allow both the projector and laptop screen and three times back to only the laptop.
Feb 18, 2008 | Office Equipment & Supplies
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
Toshiba TV Remote Control not working
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Jun 27, 2006 | Toshiba 32A30 32" TV
Runco CL-510LT Multimedia Projector Logo
Top Runco Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
