Question about Meade LX200GPS Telescope
I have a broken autostar 2 telescope controller and need a replacement but can not find one in the UK
  • 3,186 Answers
Many Meade dealers can order you a new hand controller, either Autostar II, or the 497 controller. Contact a large telescope dealer in the UK, or you can order direct from Meade here:
http://www.meade.com/support/index.html
Posted on Oct 25, 2010
SOURCE:
It lites up for 1second than goes out, the light on the tri-pod stays lit ?
Either the hand controller is broken or the hand controller cable is broken-- or you habve OLD batteries in the scope.
Aug 29, 2011 | Meade 494 AutoStar Telescope Control Unit...
My telescope with autostar will slew up and down but not from side to side.
Sometimes this can be caused by:
A bad hand controller cable
Broken gears inside
Try to look inside the base for something broken and try a new cable which is cheap. If it's a broken gear, or a burned out circuit board you will need to return it to Meade for repair.
Jan 30, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
ETX-80 hand controller say's "Self Check Failed"
You may need to reload the firmware by following these instructions for Safe Load:
From the Autostar 2.0 README file: "SAFE LOADER MODE IN YOUR Autostar:
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software (version release 1.1G and above). To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar."
This is for the 497 controller. There is NO safe load for the 494 controller.
Nov 01, 2010 | Meade ETX-80AT-TC Telescope
I need to replace my meade autostar controller battery pack. Do you know where I can find one?
Most of these telescopes will run off an outside 12 volt power pack. You never said which autostar controller you have???
Like this:
http://www.astromart.com/articles/article.asp?article_id=87
Sep 13, 2009 | Meade Autostar Telescope with Tripod
Meade LX200GPS 8" won't initialize on power up.
Try doing either a garbage collect or a safe load-- and then reinstall the hand controller firmware--
Instructions-- depending on the type of controller
Autostar 495 or 497: You enter Safe Mode by holding the [enter] and
[scroll down] keys pressed when you power up the telescope. The
Autostar will say "Flash Load Ready"... now go start the ASU.
Autostar II: if you need to use Safe Mode to recover from a disaster,
turn on the telescope, and key 999 before it says "Initializing"
The Autostar will say "Flash Load Ready"... now go start the ASU.
LX200gps: BEFORE proceeding further, click on the OPTIONS item on the Top Bar.
Now click on "Garbage Collect Hbx" ... this will perform data cleanup
within the Autostar which will avoid potential mess-ups.
Feb 27, 2009 | Meade LX200GPS Telescope
Problem with start up on telescope
Most probably, flat batteries. Autostars go berserk when batteries are even a little low. Try it with a mains power adaptor instead.
Otherwise, maybe its a dodgy curly cable, broken Autostar, broken control panel or Autostar firmware needs reloaded
Jan 29, 2009 | Meade LX200R 8 in. (600 x 203mm) Telescope
Autostar
Double check the cable from the Autostar to the telescope. Sometimes the ends go bad. They can be replaced with regular telephone cables.
Aug 29, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Etx-105ec + autostar
Dear Roger,
I think moto gear is dameged.Please check or restart your unit.
Thanks.
May 19, 2008 | Meade Optics
Computer control and pointing with NorthStar Goto & Autostar
Your reseller is correct. The wire (Meade cable #505) goes from an RS232 serial port on PC to a 4pin RJ plug. This plugs into the 2nd socket on the bottom of an Autostar 497 handset, the other socket being used for the curly lead to the telescope. So it goes PC to Autostar to telescope.
A common error is to try plugging the serial wire into an "AUX" ort on the telescope control panel - same connector. Not only does this not work, it can cause a lot of damage.
Wired like this you can control the scope from Meade's Autostar Suite (or many other planetarium softwares). You can also update the Autostar software to the latest 2009 version.
What else can go wrong? Well, many people want to control from a laptop, and modern ones don't have RS232 serial ports. Then you need a USB-to-serial convertor dongle, which effectively add a serial port to a laptop. But they often give it a very high port number (eg COM17) that the planetarium software does not find. Use Control Panel to reset the USB-serial-port to COM 1, 2, 3 or 4 and all should be well. But it can be a right fiddle!
Apr 01, 2008 | Bushnell NorthStar Goto 100mm 788840...
Meade LX200GPS Telescope Logo
374 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Gep Pep
Ekse
Are you a Meade Optic Expert? Answer questions, earn points and help others
